Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a steel line brand remote control roller door taht when i press the button to close the door it goes down about 1-2 feet and then starts to go back up.For it to close i need to stop the door before it goes up and then press it again,goes down 2 feet and so on. Takes about 7 times before it closes. Any Help????
There must be something blocking or making it difficult to move, check the belts and lubricate the moving rollers.
Posted on Oct 22, 2008
It opens but won't close unless I hold down the wall control button.
the photoelectric safety sensors are not working. either they are not lined up or they have a broken/disconnected wire. door goes up without them working, but will not go down without the safety system working unless you press and hold down button.
Mar 23, 2015 | Building Materials
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Having trouble setting garage door opener to my 2004 trailblazer
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
source:chalkstar100 (fixya mate)
Thanks for using Fixya
Have a nice day!
Mar 07, 2009 | 2004 Chevrolet TrailBlazer
I have a remote control 4 in 1 RCA and dont work with me tv brand SIMTRON
Try this.. turn on your tv. Press the and hold the TV button till it blinks, then press the search button, do not hold it down.. Press it and keep pressing it till the tv goes off. Once it does. Push the TV button again and then the POWER button. TV should come on.. Good Luck
Oct 24, 2008 | RCA 4-in-1 Universal Remote Control
Remote garage door opener
1-800-355-3515
www.homelink.com
Problems:
Oct 11, 2008 | 2003 Acura MDX
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
159 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
