Question about Zanussi ZSS7 / 5W Compact Refrigerator
Fridge not working
We have a zanussi zfc 45/30ss. The lights are on and the motor appears to be running, but the fridge or freezer does not get cold.
  • 237 Answers
Sounds like the refrigerant has leaked out of the system.
Posted on Dec 23, 2006
Zanussi freezone fridge freezer model number zfc 50/17 freezer working fridge not
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 27, 2011 | Zanussi Refrigerators
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZSS7 / 5W Compact Refrigerator Logo
315 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Jason Harris
Jason Harris
Brad Goodale
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
