Question about Kenmore 15129 Built-in Dishwasher
Top Rack not cleaning
Model 665. My top rack cleaner is not spining. Water does come out of the hols.
  • 1 more comment
  • bask6 Dec 01, 2008
    we have the same problem with ours, how do i fix it??
  • richertt Dec 06, 2008
    Same problem here. I did notice that there is not very much water in the basin.
  • Anonymous Mar 31, 2014
    Model number 665
I Figured out my problem. The top rack cleaner was not spinning because there was not enough water pressure to turn it.
The water pressure was low because there was not enough water in the basin for the pump to work.
I had a defective drain solenoid which would not de-activate and caused the basin to drain too rapidly. I replaced the solenoid and everything is fine.
Posted on Dec 22, 2008
If you have the model with a garbage disposal, more than likely the chopper assembly broke. It's a fairly straight forward fix. Sears part# 8268383.
Posted on Dec 21, 2008
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher doesnt wash top rack ....model 665 1352k700...ser fu4706403
Jan 22, 2010 | Kenmore Dishwashers
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Top rack whisperquiet dishwasher no water
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
Top rack not getting clean
you may have a bad chopper. put a couple of coffee mugs upright on the top rack turn the dishwasher on and see if the mugs are filling with water give it about 1 minute. if they are mot filling up you have a problem with either the recurculation pump or the chopper. it's usually the chopper
Mar 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore 15129 Built-in Dishwasher Logo
250 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
