Question about Garmin StreetPilot C330 GPS Receiver
My Garmin streetpilot c330
It is frozen and won't turn off.
  • jcarrier0304 Oct 22, 2008
    i was tring to down load new maps, and it didn't work. now my garmin is frozen and will not turn off.
  • Anonymous Oct 26, 2008
    frozen up on arrival at my location and wouldn't shut off and bussed on battery power.garmin street pilot c330 earlrandy@wowway.com
Peel off the plastic part that says Garmin that surrounds the screen.. there is a button there that says reset.. press it... though.. you may lose some data.. not sure.
Posted on Oct 23, 2008
My GPS C330 got frozen and it does not want to turn off or on how can i fix it
reset it when it freezes in ON mode. if it comes back to normal then next thing u should do is get on to garmin.com and install any available update.
Jul 25, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin 550 frozen screen will not turn off
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Aug 03, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
GARMINC330
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
Link for updating firmware select your model
hope this helps .
Mar 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps
reset button under thin band on face plate. mine did the same thing
Jun 25, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
117 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
