Question about Hampton Bay HBLG5004 Air Conditioner
Heater on my fairly new air conditioner
The heater on my air conditioner has stopped working.
yesterday morning my girlfriend turned it on for the first time this year and
the blower worked but no heat at all.
    Novelist:
  • 124 Answers
SINCE YOU SAID AC I ASSUME YOU HAVE ELECTRIC HEAT. IF BLOWER IS ON BUT NO HEAT THEN YOUR HEAT STRIPS ARE PROBABNLY NOT BEING TOLD TO COME ON OR THE BREAKER TO THEM IS OFF. SOME TIMES THE BLOWER IS ON A BREAKER AND THE STRIPS ARE ON A SEPERATE. CHECK ALL BREAKERS. THEN IF STILL NO HEAT YOULL HAVE TO CHECK THE POWER TO THE HEAT STRIP RELAYS . SEE IF THEY ARE BEING SENT A 24 VOLT SIGNAL TO RUN AND THEN CHECK TO SEE IF THEY HAVE POWER INTO AND OUT OF THE RELAYS. IF YOU DO THEN AN OVERLOAD OR A FUSEABLE LINK OR THE STRIPS THEMSELVES ARE BAD. EACH 5 KW OF HEAT SHOULD PULL 20 AMPS . IE 15 KW PULLS 60 AMPS 10KW PULLS 40 AMPS ETC.
Posted on Oct 25, 2008
My air conditioner stopped blowing air
Your blower motor is probably bad.
Apr 28, 2014 | Heating & Cooling
I have air conditioner/heater will not come on after working for a while this morning.i alreaetdy tried reset button and doesnt help
if the aircon is running to heater and the temprature outside is really cold [ sorry do not know the exact temp] the evaperator at the back will ice up and stop the aircon from working.if this is the case you just have to wait for the ice to melt. hope this helps cheers
Oct 19, 2013 | Haier Heating & Cooling
Hello i have a pacl90 delonghi portable a/c and my girlfriend put in the car on its side. by the time i got it to the new location it was making a hissing noise, like the freon was leaking out. we stood...
Yep a line broke, most small units are not worth fixing, but it can be repaired, there is a fair amount of work involved, hence the cost. Not like it used to be, in the days gone bye.
Jul 02, 2011 | DeLonghi Pinguino PACL90 Portable Air...
I have a Rudd Achiever 10 . The unit was working yesterday morning, it stopped in the afternoon , and is still not working. The fan in the unit in the basement is working fine. Do you think it could just...
you will need to check you condenser unit(the outside unit) here is a website that may help,Tim:
http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-troubleshooting.html
May 30, 2011 | Ruud UBHC Air Conditioner
My contactor switch will not remain engaged. I
Something,is drawing too many amps,most likely the compressor.
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
My room air conditionar is not blowing out cold air,please help
if the compressor is running then the refrigerant has leaked out and repairs on that are 140usd+ , check the warranty on it.
Phil
Jun 10, 2009 | Heating & Cooling
Heater furnace doesn't want to turn on'
Did the fan turn on, if it did when was the last time you cleaned the filter.
Mar 14, 2009 | LG L1004R Air Conditioner
Screeching noise when I turn on my air conditioner or heater
It may just need to be adjusted (it sounds like it's too loose). If the belt isn't cracked or frayed, you should just have it tightened up a bit . If there are signs it is worn (cracked frayed) replace it.
Oct 24, 2008 | Hyundai Motor 2004 Sonata
Heating & Cooling Logo
113 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
