FixYa.com
Tags:
Sanyo C40N
No sound (by 4 users)
posted by baterdene on Jul 28, 2006
I bought a Sanyo CE28WN7-B television in the UK and brought it to Mongolia. It worked fine in the UK. But, in Mongolia, it had a very poor reception (poor picture with normal sound) with an aerial. Recently, it has been connected to a cable TV service, which improved the picture quality to normal, but NO SOUND. Could you tell me how to solve this problem? Please find the TV specifications below:
Television system: System I
Colour system: PAL/NTSC4.43 (PAL/NTSC4.43/NTSC3.58 in AV mode)
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 08, 2008
C- Media A C97 Audio Device
Comment by meohuone15, posted on Jan 06, 2008
I Bought a New Sylvania SDTV  and hooked up my stereo just as the tv manual said ......It doesn't work  it worked on my older Magnavox  I've went to AUDIO SETUPS  on both remotes what can it be????
Comment by Guest, posted on Dec 04, 2007
my problem is how to enter option menu and other menus.
Best Solution
posted on Aug 01, 2006
Thanks for Trying (70)
2296
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 03, 2006
Not Rated (0)
Pravin
Rank:Wiz Wiz
Rating: 83%, 556 votes
Mongolia Broadcasts on SECAM-D Standard. So you have to go into the SETUP MENU of your TV and select SECAM in the SYSTEM Options.
In sound select 'D'. UK broadcasts in PAL - I.
It is a simple matter of resetting the TV.
This Problem Also Relates To: Memorex 13662375 Audio Cassette (Type 1) (7-Pack) Memorex 14112000 Audio Cassette (Type 2) (2-Pack) Panasonic 126 Mins. DVC PRO VIDEO CASSETTES - LARGE - AJ-P126L DVCPRO Tape Panasonic 10 Pack BOX MINI DV 83 MINS - AY-DVM83MQ - AWESOME MASTER SERIES Mini DV Tape Panasonic 10 Pack BOX MINI DV 83 MINS - AY-DVM83PQ - AWESOME PROFESSIONAL USE Mini DV Tape Sony 10 pack 94 MINS DVCAM PDV-94N DVCAM Tape Sony 10 pack 120 MINS Hi-8-Digital 8 - P6-120HMPX - PROFESSIONAL Hi-8 Tape
Can you Help with these Audio and Video Media problems?
microphone
kayy, my webcam microphone... Answer This...
Hola le? tu post
Hola! No es que no entienda tus... Answer This...
video graphics control and...
sir i want download free audio... Answer This...
AWA DP 239 DVD PLAYER
Hi, just wondering if you guys... Answer This...
VCR /dvd dual, Magnazox,...
My Magnavox can not communicate... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
