Question about Olevia LT37HVS 37 in. LCD HDTV
Olevia 237V S11 Backlight Problems
The backlight on my Olevia 237 flickers all the time, it give the picture an annoying strobe light effect. I have replaced both inverters and there was no change in operation. I have replaced transistors and capacitors on the secondary side of the power supply with no change in operation. I haven't found a replacement power supply yet to try. What else is possibly causing this problem? Has anybody fixed this same problem? Thanks.
  • 1 more comment
  • jaminlive Nov 03, 2008
    I have the exact same problem. I hope someone can help.
  • aaronpfeifer Nov 23, 2008
    I ordered a new power supply from Olevia, their customer service couldn't get much worse than it is right now. New power supply fixed the problem, it cost $98 plus $10 shipping. It only took me a couple weeks to get a hold of somebody to order my power supply.
  • paulemith68 Dec 03, 2008
  • Olevia Master
  • 5,568 Answers
This sounds like a defective batch of fluorescent backlight sources; have seen this complaint before.
This may be tough to acquire since I don't know how standard those are across the industry and Olevia has filed for bankruptcy so you can't count on them.
Posted on Nov 23, 2008
  • Steve Allison
    Steve Allison Nov 24, 2008
    I would really like to have a bad supply in possession since I once had an active business repairing switching power supplies some years ago and suspect I know what is causing this type of failure.
    The actual model origin isn't important and I haven't had the misfortune yet of having one of mine fail.
    If you would be willing to let go of yours (assuming you still have it) I would be willing to send you a check in advance for whatever residual value you place on it and a few bucks for packing and shipping it.
    I don't really have any wish to retire from retirement so it would be a matter of curiosity more than anything.
    And, as an added incentive, I would return the supply to you if it can be repaired so you can replace the one you just bought with one that will most likely never fail.
    I know these beasts.
    If this might be of interest, please email me at the (corrected) address below: (small 'L' in lycos, not an 'I')
    Thanks -
I have a 42" Proscan
It sounds more like a backlight problem to me. The first thing I would try before tearing the set apart is simply unplugging it for about five minutes and plug it back in. TV's do weird things sometimes and need to be reset. Odds are, if you have to open up the TV, there's not a whole lot you can do anyway. Check the backlight on signal and also see if your inverter is working. I would suspect that if you're strobing your backlight is probably dying. In that case all you can do is replace the panel; you could try finding a replacement backlight and installing it, but I wouldn't advise even trying this. Replacing backlights is quite a task if you're not familiar with televisions. Anyway, best of luck.
May 01, 2011 | Proscan 42LED55SA 42 in. LCD TV
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
I need the firmware for an olevia 237-s11 can you tell me where i may download it
hi you can download a firmware from the below attached link
Nov 22, 2009 | Syntax Olevia 537H Television
I have sound but no picture on an Olevia 237V
If you get no picture on all inputs (TV, DVD, ETC.) then the problem can be in the backlight inverter board or the power supply that supplys the power to the inverter board.
Nov 01, 2009 | Olevia 237T 37 in. LCD TV
Flashing picture
I had the same problem with my 237V, I had to replace the power supply to fix the problem. I believe when it would work the output voltage of the power supply was around 19.2v. When the screen started to strobe the voltage had jumped up to 21.5V. A new power supply fixed it for me but now I think my main board is on the fritz.
Sep 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 237V S11 Firmware
for all firmware updates you must go to this site
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Check inverter supply voltage, (should be constant and stable) if found ok, then inverter or back-light tubes are suspected.
Sep 06, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
474 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
