Question about Dell Inspiron 6400 Notebook
Laptop keyboard do not work & system restart automatically
Hi ,
I have Inspiron E1505 laptop. 3 days i have spilt juice on the keyboard. Since keyboard was not working. I removed the keyboard , cleaned it and put it back in place. It started working, but every now & then it stop working and restart automatically. But no problem with mouse.I tried using external wireless keyboard and has the same problem. Please suggest & help.
Thank you,
Ravi
    Problem Solver:
  • 9 Answers
For the second problem, you need to unplug the memory and refix it after cleaning the memory module and also the memory slot.
Posted on Nov 12, 2008
HI Walterb,
Thank you for your answer.
I have one more question.
I wanted to check the motherbaord before i replace it. So what i did was removed the palm cover, modem & memory , cleaned the motherboard for dust and other place on palm top. Actually the juice had not touched any place on the board.
But after i assemblied everything, The computer do not run nor the display. My laptop will only power on for couple of seconds and turn-offs automaticall. Please suggest & kindly help.
Thank you & will be looking forward to hear from you.
I would like to talk to you regarding this issue . Please give me your contact # or i can be reached at 757-553-4157.
Regards,
Ravi
Posted on Oct 23, 2008
  • Dell Master
  • 998 Answers
You probably got juice on the motherboard. I’m afraid the only solution is to have the motherboard replaced. There might be a chance that the juice will dissipate after time.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 22, 2008
I spilled juice on my Toshiba L505 s5993 laptop, and now the keyboard will not work. Please help.
Wow, bad luck day. immediately flip the laptop upside down in an open position so the keyboard is flat on the table use some paper towel under the keyboard... more comments. to follow... do this immediately
Aug 30, 2010 | Computers & Internet
How to replace a keyboard on dell inspiron e1505
The Inspiron 6400 and the E1505 share the same disassembly guide. Follow the link below to see an illustrated view of this procedure.
http://ahwee.com/how-to-disassemble-laptop-insp6400
Jun 01, 2010 | Dell Inspiron E1505 Notebook
I spilt alcohol on my laptop and now the keys dont work
replaced ur keypad from the nearest hp service centre.
Apr 25, 2010 | HP CPQ175KB Keyboard
Need directions to install a new Dell E1505 laptop keyboard
If you need to ask "how", you should NOT try -- take the computer to a qualified and certified technician who _knows_ how to do it.
Nov 09, 2009 | Dell Inspiron E1505 Notebook
I spilt a glass of juice over my husbands keyboard and now it wont work properley! can i have this repaired for him or shall i just buy a new one?
Hi, Jenny.
If you are talking about an external keyboard, it's not worth repairing and easy to replace. A keyboard on a laptop is more difficult to replace, but also not worth repairing.
Since juice is acidic, the circuitry on the keyboard is probably destroyed.
Hope this helps.
Oct 04, 2009 | Microsoft Computers & Internet
I have media direct on laptop inspirion 1505...it was not being used and now it comes on automatically and i can not get to opening page for password to internet. when I exit media direct express, the...
First hit ctrl-alt-del at the same task manager will open and you can shut it down there then go to control panel and click on add/remove programs, select media direct and click uninstall
Jul 27, 2009 | Computers & Internet
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
The whole keyboard
just wait as it may dry out .
if not a keyboard can be order on ebay for around 30.00
Feb 25, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Notebook Logo
143 people viewed this question
Alun Cox
