Question about HP Office Equipment & Supplies
Printer paper jams when loading to print
Paper jams when loading hp 8050 printer.have cleared but still jams when loading,right hand corner seems toget stuck in roller at backwhen paper feeds
5 Suggested Answers
SOURCE: paper jam
Mine just started doing that, too! That's why I came to this site! Can anyone make a suggestion?
Posted on Jun 20, 2007
SOURCE: paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Posted on May 08, 2008
shivam4529
  • 150 Answers
SOURCE: Paper not feeding in the
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
Posted on Jun 18, 2008
yooperbud
  • 8637 Answers
SOURCE: printer says clear paper jam. There is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
Rollers could be worn out. Also could be a problem with the paper sensor. Not sure what type of sensor this printer uses. Some just use a pressure switch, others use a light sensor.
Posted on May 18, 2009
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
My printer reports a 86.01 error which seems to associated with a paper jam. I have opened it to clear the jam yet there is no paper jammed on the printer. This printer cannot load the roll paper for...
The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service
Station cannot uncap the Printheads. Or the service station is defective or the carriage belt is broken and the carriage can't move.
May 18, 2011 | HP DesignJet 500 InkJet Printer
We have HP Photosmart 8050. We had a paper jam but was able to clear it. However, it will not print from the computer. We were able stat and color alignment page, so we know paper is getting through and...
There will be something in there, whether it is toner/ink over a sensor, a paperclip/staple, or a tiny scrap of paper.
The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Oct 29, 2010 | HP Photosmart 8050 InkJet Printer
Display permanently indicates
Unplug the Printer and Disconnect it from the Power Supply. Then Turn it Back ON, after few minutes say 30 minutes, that would fix the Problem.
If Problem Persists, Check the Machine Once again to make sure that you do not have any Paper Jam.
Refer the Manual to Clear Paper jam, if any. If you do not have the Manual, Revert to me and i would be glad to Offer you the Manual.
In fact, Check Below Link to Clear Paper Jam :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00438945&lc=en&cc=us&product=454816&dlc=en#
Now,
If there is No Paper and still the Message is there, more likely, the sensor has gone bad and needs replacement.
If under Warranty, get it replaced without any Charge unless Hp would charge you more than half the amount to get this Fixed. Still not a Bad idea to call and have a Quote and if the amount is too high, do not shy of asking for exchange in lieu of this. They could Offer you a Nice Discount as Christmas is already here :)
Note - Also Try to remove the Cartridges and again Re-Seated them Properly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 22, 2009 | HP Photosmart 8050 InkJet Printer
My printer prints, but after each page a paper jam appears when there is no paper jam, I press ok and it prints the next page. How can this be solved?
From the sounds of things, the issue may be a logic board issue if it is erroring out the same way each time. Many times a small scap piece of paper can get stuck inside the printer causing the paper error, but pressing the OK button would not clear the error which leads me to believe it is a logic board issue. May be time for a new printer.
Feb 17, 2009 | HP Photosmart 8050 InkJet Printer
Hp c6180 keeps erroring that there's no paper, when it does recognize paper
folded corner is 2 things
a) it's gettig folded somewhere along the paper path ( you would have to stop it at every step to see at what point it gets folded)
b)usually the fuser claws are the problem ( right before the exit the part that gets hot has some claws that ride ON the heat roller 3-5 depending on the machine, one is going bad )
Aug 18, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Photosmart 8050 printer won't load paper.
hello SuperVicky, rollers on the printer do not go that often on the other hand the usage of the printer is a factor ie how much printing you do or age if old. Normally paper roller should allow you print quite a few thousands before wearing out. what i will advise is to look keenly in the printer shuold in case you have any particules in the paper path of the printer or after paper jam it is possible to have a residue left in the printer. all these can be a problem.
Aug 10, 2007 | HP Photosmart 8050 InkJet Printer
49 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
