Question about JVC THD-50 System
My jvc th-d50 surround sound wont power up please help me fix my problam
I was drinking one night and was jamming my surround sound on full blast and it just shut off on me now every time i turn it on it go right back off and right to the red power light it wont turn on to the blue screen i just bought this less then 3 mouths and it kicks *** so please help me thank you very much and thank you for your time
  • 1 more comment
  • sjmertens Dec 31, 2008
    I have the same problem; less the drinking and jamming at full blast.
  • Anonymous Jan 20, 2009
  • Fever1029 Feb 04, 2009
    can someone please assist with this problem because my JVC has fallen down this path. The power continue's to cut out, finally i was able to power it up but now it won't register any sound....
5 Suggested Answers
s4u311
  • 813 Answers
SOURCE: JVC TH-A9
1st u need to covert stereo cable with stereo conversion pin which avelieible in electronic consumer store after u got this cable u able to connect ur speakers directly to play station or a tv
Posted on Feb 19, 2008
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
tech48
  • 624 Answers
SOURCE: JVC TH-M505 No Sound
It is possible that a fuse has blown in the sub-woofer box. This unit has the entire amplifier built right into the sub-woofer. It also has a number of fuses in it. I have found that over the years fixing these units that if a fuse is blown you will also have more serious problems in the amp circuit. That is usually why the fuse will blow. They sometimes even have a problem in the main head unit with a digital transistor that is a surface mounted transistor that will cause this problem also. This transistor is part of the turn on circuit that signals the sub-woofer to turn on when the head unit is turned on. None of these problems are an easy fix I am sorry to say.
If you have at least a little experience with electronics and the right tools, like a multimeter and soldering equipment, I may be able to help you figure out the problem. But be aware that these are not easy to fix, and you may spend lots of time trying to figure it out just to find out that you will still need to take it in to a service center and in many cases when somebody tries to fix these type of units and have no experience with them they often cause more problems than they have started with.
For starters you can at least check the fuses, but please be sure to unplug the entire unit from the wall outlet before doing anything, there is a big risk of electrical shock.
The bottom of the sub-woofer has 6 screws in it (If I remember right) and those 6 screws must come out, they are rather big and you must use a number 2 phillips head screwdriver. Then after that you must take out all the screws from around the edges of the black metal panel where the speakers plug in to. When those are all out you can pull the amplifier unit right out of the sub-woofer box. Be careful when you pull it out, you will need to unplug a set of wires to get it all the way out, maybe two sets of wires, I am going off of just my memory right now, but if you need more help I will look up the service manual to help you more.
You will find at least one fuse right near the board where the A/C plug goes to and then you will find a few more fuses on the board that is on the right side while looking at the amp block from the same position you pull it out from and this board is plugged into the bottom board and is vertical but the short side is up and down, the long side is going towards the back of the amp and it is running along the metal chassis on that right side.
I hope this helps you, if you need more help just post your questions here.
Dave
Posted on Nov 26, 2008
SOURCE: Cannot TV to play throught JVC TH-C50
i have a jvc th-c60 and only recently started using the system for surround on my tv.
in addition to the surround system, i have a conventional vcr/dvd player. i mention this because i have my cable line routed through the vcr/dvd player - all other connections (audio in/out, etc.) are directly from back of tv to surround unit console. assuming all connections are correct, set the jvc unit to show "VCR" on the unit display AND set your surround option to "All surround". The "all surround" may not the exact term, and not sure what your unit has the same notations, but you should be able to cycle through the surround options and determine when you have sound coming from all speakers. also, on my th-c60 unit, the unit display denotes which speakers are producing sound (or should be producing sound).
and, yes, the college football games sound awesome in surround mode.
Posted on Jan 09, 2009
SOURCE: Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Posted on Mar 01, 2009
I have a JVC surround system, I have power to both the DVD player and the Subwoofer but no sound. Wheni plug in earphones to the dvd player there is sound but nothing when unplugged. Could it be the S
You must have an external cable connection from the DVD audio output to the surround DVD input. As well there should be an output from the surround marked subwoofer. Connect them with the proper cable
Apr 04, 2012 | JVC TH-S8 System
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for...
This is a 2-part question. You can get ALL speakers to SIMULATE a surround experience from ANY input, even 2-channel analog.
If there is an optical digital audio output on the Dish TV receiver use THAT and the TH-G30 can decode the surround audio properly.
Read up on surround modes in the manual.
Jun 07, 2011 | JVC TH-G30 Theater System
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
How do I get tv sound thru my TH-D50 srround sound speakers?
your tv needs and audio output if it dosent have one get an old vcr or vvd plaver that does, plug your system to the vcr and vcr to the v. the vcxr needs to be on if you want sound.
Apr 03, 2010 | JVC TH-C50 System
Once watching a dvd it wont let me change the surround that i want. How do i fix it?
Apparently, the use of the built-in DVD player doesn't allow sound field manipulation; but external sources can be modified. This subject is only discussed in this section of the manual...
"Enjoying audio form an external
source
You can enjoy audio form an external source through
your unit.
Press INPUT repeatedly to select the desired input
source. - AUX, AUX OPT, AUDIO IN
Setting the surround mode
You can select the Dolby Pro Logic II. Press
SURROUND to change surround mode repeatly...."
Mar 15, 2010 | JVC TH-G30 Theater System
Problem with surround sound on JVC Th-C5 sound system
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
Dec 25, 2009 | JVC TH-C5 System
Surround System setup
Hello
I did not find HVC(DId you mean JVC?).
If you meant JVC i found a link where you can download the Manuel,
http://www.retrevo.com/support/JVC-TH-M505C-Home-Theater-Systems-manual/id/318bh527/t/2/
Really hope this can help.
Oct 13, 2009 | JVC TH-M505 System
Hi How connect my wii through JVCTH-D 50 SYSTEM
the reason that you cannot see the wii is because the yellow connection on back of th-d50 is an output not an input. you will need to connect the yellow to your tvs input if possible, and leave the red and 9hite for audion on th-d50. if wires are attached together, then you will need to connect your wii directly to tv, and then use a set of red and white cables to connect from audio outt on tv to audio in on jvc unit.
Feb 21, 2009 | JVC THD-50 System
JVC Surround Sound System
The problem on your sub is your speaker is faulty the end of the speaker coil is burnt so at a certain volume it`s makes a short .I hope that would solve your problem:)
Dec 29, 2007 | JVC SP-PW100 Subwoofer
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
JVC THD-50 System Logo
359 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
