Question about Konica Minolta DiMAGE G500 Digital Camera
Memory card sd
I dowloaded some pictures from my computer into my memory card SD which was initially empty. When I installed my card into the camera to view this pictures, he doesn't see anything.
can you help me?
Dan
  • daniboud Oct 22, 2008
    Hi Benimur,
    Thanks for your help!
    I did format the card using the digicam but it doesn't seem to work. I think your second hypothesis is the good one: the pictures don't match the image property requirements of the camera. I have the following message when I try to view the pictures in the digicam: UNABLE TO DISPLAY. What can I do? I think the way I dowloaded the pictures from the computer to the SD card is the issue; I simply copy them but I don't see any other way to do it.
    Can you help again?
    Thanks.
    Dan
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
It would seem that you would have to do it all over again, that is download the pictures again to the SD memory card. But before doing this, you would need to format the SD card using the digicam rather than the PC.
In some cases, it maybe that the picture files (downloaded from the computer) does not match the image property requirements of the digicam so that even if the image files are stored in the SD memory card, the camera is unable to list/view them
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
  • Louie  Role
    Louie Role Oct 23, 2008
    Hi again,
    I was made to understand that the images saved/viewable by a Minolta DiMAGE G500 should be:
    • 2592x1944, 2048x1536, 1600x1200, 640x480 Image Resolution;
    • file type jpg compressed format;
    • image width 2560 pixels;
    • image height 1920 pixels;
    • color depth 8 bit.
    There are utilities/programs that can alter the properties of an image file. One that I use if ACDSee. You could try a Google search for freewares.
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
Why does my camera display 'Out of Memory'?
Your camera comes with a very small internal memory. Your camera may be telling you your memory is filled up because it is. First, if you do not have an add-on SD memory card for your camera, get one and install it following your camera's instruction manual. Second, if you already have an SD card installed or you put a new one in, go to your camera's menu. There will be an item that allows you to use either the camera's internal memory or the add-on memory. Make sure the add-on SD card is selected.
Jul 04, 2014 | Nikon COOLPIX Cameras
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 | Cameras
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
I can't dowload pictures to my Apple Mac because the SD card doesn't fit. Is there some type of adapter for this?
You can get a little card reader that plugs into a USB port for a couple of dollars. Some of them will accept different types of memory card, but the cheapest just do SD cards (if you are sure it is an SD card).
Dec 04, 2010 | Optimus DS-5080 Digital Camera
My camera says the pictures upload onto my computer but then nothing happens after that....the pictures dont upload what is the problem?
Internal Memory: 32MB
SD Card / SDHC Card (Up to 4GB support)
Possible that internal memory is empty and your are transfered zero file. Switch to external SD memory in your camera menu should take care of the problem. Get the SD card reader is your easiest option. just copy and paste the photos to my picture in your computer.
Apr 05, 2010 | General Electric A835 Digital Camera
Missing pictures on sd card
I had success with this
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download SD card photo recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Mar 29, 2009 | Kodak EasyShare C613 Digital Camera
Sd card
when you camera is connected, go to my computer and you should find it listed under other devices, you should then be able to explore the camera folders in which sould be your sd card folder, copy and paste them.
Sep 06, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Konica Minolta DiMAGE G500 Digital Camera Logo
218 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
