Question about HP PSC 1610 All-In-One InkJet Printer
Printer states out of paper
It states out of paper,i take paper out and put it back,then try again.it still comes back out of paper
    Scholar:
  • 181 Answers
The gears in the printer are worn out or getting blocked some where and the printer needs sevicing /cleaning internally to make this clear.
Posted on Nov 13, 2008
Replaced cartridge won't print
Step followed:-
1. Remove cartridges.
2. Press and hold the Power Button and remove the Power Cord from the back of the Printer(in printer ON state).
3.Shake the cartridges and clean the cartridges.
4.Clean the printhead softly from cotton clothe.
5.Put the cartridges again.
6. Press the power button and connect the power cord.
7. Clean and allign catridges from printer control pannel.
This might can help you and try to put some thick paper instead of normal paper.
Apr 05, 2014 | HP PhotoSmart Office Equipment & Supplies
Printer will not feed paper, states a paper jam but none to be found
Hi,all you need to do is to take off the papers and re-arrange them.just try to do that and put the printer off and put it on back.
Take care
May 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My printer won't feed paper. All of a sudden my printer quit feeding the paper - the error light comes on and states that there is no paper in the feeder - but there is paper in the feeder
Check the paper feed switch, you have a choice to feed paper from the back or the cassette under the paper exit. Either put paper in both or select the proper source by pressing the feed switch.
Dec 30, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Canon MP600 paper jam
alternative :
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer keeps stating paperjam but there is no paper in it
Check the back of the printer. There should be a removable rear panel. Just Pull back on the lever (I believe on the right side) The rear panel will come off. See if any paper is lodged along the paper feeder wheels, if so, just remove it.  Also check back in the front of the printer and make sure there is none lodged along the feeder there where the paper normally comes out.
Power the printer back up and try to print again.
Hope this helps
-enov8
Mar 07, 2009 | HP Deskjet D1420 InkJet Photo Printer
Paper light continually flashes won't print
when you lift the cover on the back of the printer there is a thin plastic sensor very delicate normally black in colour which detects whether there is paper in the tray or not.that sensor is slightly moved from its orignal position or broken , so this problem is coming.
thanks.
Sep 18, 2008 | HP LaserJet 4L Printer
HP Deskjet 3940 (Paper Jam)
I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
Paper thickness lever postion
Is there a lever inside the printer that can be moved back and forth? If so set it about half way and try again.
Jan 17, 2008 | Canon SmartBase MP360 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
