Question about Toshiba 20AF43 20" TV
Cluster of stuck pixels
I have a Toshiba 20AF43 TV (standard flatscreen) that I purchased in late 2003, which was working great until recently. The screen has developed a 4x4 cluster of stuck pixels (maybe not the right word, because this is not an LCD) in the upper right hand corner of the screen. These pixels are located just below the channel number and label, and are the same bright turquoise color as the text. They remain stuck on even once the channel number and label have disappeared. However, if I mute the sound or go to the control menus the blue spot disappears and the picture displays normally (i.e. the pixels are not dead or burned-in). I have tried restoring the factory settings and clearing all the channel labels and changing the display settings in the menus, all to no avail. I can't seem to find any information in the manual on this problem. Thanks in advance for any advice you can offer.
    President:
  • 3,130 Answers
Sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Posted on Jul 28, 2006
SOURCE:
White spot on screen
Sounds like you are describing stuck/dead pixel.
There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel
Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
Jan 12, 2008 | Samsung HL-P6163W 61" TV
How to watch dvd on a toshiba 20af43 without original remote control
To remove the video lock:
1. Press MENU, then press left or right to display the OPTION menu.
2. Press up or down to highlight LOCK.
3. Press left or right to display the LOCK menu.
4. Use the Channel Number buttons (0-9) to enter your PIN code,
then press ENTER. The LOCK menu appears.
5. Press up or down to highlight VIDEO LOCK.
6. Press left or right to select:
• OFF: Unlocks all video input sources.
Jan 05, 2010 | Toshiba 20AF43 20" TV
Power red light comes on and blinks off you can hear it click but doesn`t have picture come on. i must unpug my tv other wise it keeps on clicking.
Greetings!
You have a great little set. These made a great picture. It is impossible to tell without inspecting it myself, but the most common things we found on this era of Toshiba was open flyback transformers and shorted horizontal outputs. Neither of these do I recommend you attempt, because you will be working in the high voltage circuit and can subject your self to unhealthy voltages (in excess of 30,000 volts). Refer this to a qualified technician, but a fair and honest one who will charge you a fee that will make it worth repairing. Make sure he/she checks the socket on the picture tube, too.
Good luck,
Rob
Jan 14, 2009 | Toshiba 20AF43 20" TV
No power
check the fuse
Sep 05, 2008 | Toshiba 20AF43 20" TV
TV Trouble: Toshiba Flatscreen CRT (Brazilian model: Linha Face)
i suggest if you buy it few months ago that item is under warranty
you to call the toshiba service and try to have changed with another
one or get free service - delfo
Mar 21, 2008 | Televison & Video
Tv turns off right after its turned on
you need a hyphen goofenator pump. easily installs in about 12 working days and is redily available at walmart.
Jan 04, 2008 | Toshiba 20AF43 20" TV
Dead Pixel in Toshiba Porteg? M600 laptop
Without rplacing the main part of the lcd, I'm afraid you're stuck.
Nice laptop. Toshiba service has always been reasonable in my experience.
Sorry I couldn't offer better advice.
Good luck
Nov 25, 2007 | Toshiba Portege M200 Notebook
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Toshiba 20AF43 20" TV Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
