Question about Garmin GPS
My Nuvi 660 powers on but fails to locate satellites. I have updated the machines but alas no workie. Please help
  • Garmin Master
  • 2,130 Answers
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Posted on Oct 22, 2008
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
My Nuvi 660 can not locate the satelites, please advise. Thanks.
There is a common problem in the antenna circuit that will cause the antenna to fail. To confirm this take a very small section of wire and carefully insert it into the center conductor of the external antenna jack, which is located on the side of the flip up antenna. By doing so you are essentially using the wire as an external antenna and the unit should get satellite lock. Do not continue to use the wire as antenna however. Garmin will charge a flat rate of $110 to repair it or you can send it to a reputable post warranty repair company like www.sharcnet-usa.com
Hope this helps you, safe travels.
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
Lost satellite connection
Please see this link for more information on this problem. Too much info to cover here:
- Jim
Aug 05, 2009 | Garmin Nuvi 660 GPS Receiver
My nuvi 660 all it says is acquiring satellites
Try reuptdating your GPS or reset it it might be a bad patch.
Jun 23, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Try performing a reset of the unit. Hold down the bottom right of the touchscreen and turn the unit on. It will ask you whether you want to reset allk data. Choose yes and try again. This should solve your problem. Hope this helps.
Feb 20, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 - can not locate satellite
Please read this solution, which might help you. On the 660, you press and hold the upper-left hand corner of the screen while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 06, 2008 | Garmin Quest 2 GPS Receiver
Dont Aquire Satellites
Ditto.. even after updating FW...
Jun 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 not locating satellites
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Dec 25, 2007 | Garmin 010-00358-00 GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
