Question about Bissell 6594 PowerForce Bagless Upright Vacuum
How do I clean my Bissell Bagless Upright?
I want to clean my unit but I want to make sure that I can use water on the inside of the bagless unit. It is a BISSELL 5770 Healthy Home Bagless Upright Cyclonic Vacuum
    Problem Solver:
**** it
clean it with moist sponge
Posted on Oct 22, 2008
Bissell Bagless Upright Vacuum not working
If your Bissell upright vacuum cleaner is not cleaning like it did when it was new, then you need to provide a bit of maintenance or service. I will tell you how you can do this maintenance to your Bissell vacuum.
First, make sure that your floor vacuum is unplugged. Then you can work safely on your Bissell bagless vacuum.
If your Bissell upright vacuum is losing suction, then the next thing to check is the canister. It is very easy to simply forget to dump the canister.
The while you have the canister out, check the filter inside the canister to make sure that it is not plugged full of dirt. This filter can be difficult to access, but a little persistence will pay off. When you get the bottom of the cup open and remove the filter, use a bit of soapy water to wash out the filter. You can then reassemble the filter into the bottom of the canister.
On the left side of the vacuum there is also a HEPA filter Bissell has there to help filter the air even more. Remove that, clean it also and replace it.
The hose is the next thing to check. You can completely detach the hose from the vacuum. Check the hole at the bottom where the hose hooks up to make sure the hole is not plugged. Then stretch out the hose and run something like a coat hanger through it to make sure that there are no obstructions inside the hose. You should be able to hold the hose up to a light and see right through it.
The last thing to check is your Bissell vacuum belt. If the belt is too loose it will slip and not spin the brush properly. Bissell belts can be purchased online easily, or in many grocery stores. If your Bissell upright cleaner has a slipping belt, it may also be because of strings, carpet pieces, etc… getting wrapped around the brush. Remove the vacuum brush and cut off everything that is wrapped around it. Always be careful of the vacuum belt after you have just used your vacuum. The belt will be very hot just after use.
These steps will help you to get your Bissell upright vacuum cleaner working like new again.
on Mar 21, 2010 | Vacuums
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
Bissell 8975-R CleanView Bagless Upright Vacuum - motor is loud when vacuuming
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>Hi,<br />Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...<br /><br />Bissell Bagless Upright <a href="" target="_blank">Vacuum</a> not working<br /><a href="" target="_blank"></a><br /><br />heatman101 <br /></span></span>
Aug 26, 2010 | Bissell 8975 CleanView Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
2 bagless bissells,filters ,hoses clean,great power.
have you looked all down the hoses making sure they arent clogged
Dec 30, 2008 | Bissell Velocity Bagless Upright Cyclonic...
Bissell 6596 bagless turbo - minimal suction & burning smell
You can reach the motor, however your motor is no longer in operable condition. This is what you hear when you turn it on. You must replace the motor for this to go away. Below is the motor part number if you would like to replace it. It will cost you about half the amount of the unit to replace.
Motor # 2032211
Dec 19, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
183 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
