When i playback a video the quality is very poor and the screen jumpy, can not make out what is there. Have used head cleaner which didnt really have an effect. Adjusted tracking but no difference.
Dear Iain, Do you route your Cable / Antenna through your VCR's Inputs (at rear) ? If yes, Do you find that the video of these cable /antenna channels is good? If the answer is yes again,then, in all likelihood, you are having a machine with dirty Video Heads.Did you use a 'Wet' Type Head cleaning cassette? If no, then I suggest you get one and use it. Again it is entirely possible that the Video Heads are worn out. How old is the VCR? How many tapes have you played back on it? Do you observe some black streaking along the edges of the images on the screen, which increase or decrease when u change the tracking? If yes, then it is time to get the Video Heads replaced.In India they would cost an equivalent of US$ 10-15. I do not know how much they would cost in your country, but it cannot be much more.
CLEAN THE HEAD WITH RUBBING ALCOHOL
These vcrs are notorious for capacitor failures on the video I/O and video YC boards. I have rebuilt several dozen of these decks, so I speak from experience. Typical repair involves replacement of ALL capacitors on these boards, occasionally needing replacement of caps on the TBC boards. Video head failure is a possibility, but I would bet on the caps.
