This problem should be removed because:
Problem with E-Machines eMachines Desktop PC
replacing the motherboarrd on my emachines w3653
my computer beeps and wont load to start;i removed and replaced the RAM, it didn't help
Solutions (1)
Yes, Michael Thomas is right. This is a POST (power-on self-test) that takes place at the beginning when you boot your computer. I think this is because the BIOS chip that came with the replaced motherboard. Take care how many beeps are and if them are short or long. Who is the BIOS manufacturer? Find the error code then go here: http://www.computerhope.com/beep.htm and determine the problem. Or search google for "post beep codes" .
Suggested Solution (1)
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Ok sweet. What kind of ram are you using?
Well when I had that problem, it turned out to be the buss speed. Yours is... well according to your comp specs is 100, but if she handles 2 gigs of ram, then you must have upgraded. Is there any more info on the original ram? ddr266is the bus speed, but this is the new ram. You might have different bus speed. See if you can find it.
Source: Beeping noise after installed memory on ecs motherboard L4S5MG
long beep on start up
just wondering why my foxconn motherboard which is working in my comp with 1gb ram stick but i recently purchased a 2gb ddr2 ram stick but...
Beeping noise after installed memory on ecs...
I wanted more memory on my pc & I recently installed extra 512mb ram into slot 2 & the pc started quckly & then slowed.On...
My dell optiplex doesn't boot...
My dell optiplex doesn't boot... but i can hear the sound (not beeping) and the spinning hard disk. Nothing is in the screen. I tried...
My Dell Dimension tower was recently knocked of
My Dell Dimension tower was recently knocked of the desk by my cat sleeping on top of if. Now it beeps 2 time and 2 times again, fan and...
acer aspire T180 wont start
acer aspire T180 wont start screen says no signal input computer is beeping cant tell beep code possibly 2 long beeps repeated or just one...
Add Your Solution
emachines kb 0705 keboard driver
it loads when i boot up but then all lights go off and its dead
i can get to control panel but then i cannot open...
i want to get into add and delete file
how do ichange the type size on my laptop e525...
I want to enlarge to type size when I print out on my hp prtinter
Top E-Machines PC Desktop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
thank you Beni i appreciate the help
