Question about GE 27GT616 27" TV
Tv no start up, fuses ok. chassis no. ctc185ab
There is no power , no noise, even no click when push the power button
    President:
  • 3,130 Answers
WOW thats an old set man!!! Its not worth even getting an estimate for, as if your not a tech my advice would be, Dont play what can kill you!!!n its time to put this puppy to sleep my friend. Buy a new one!! Good luck
Posted on Jul 28, 2006
I have an RCA DLP ,R56WH76, it wont' turn on period.
follow the power cord to where it plugs into the small AC filter board on the right side looking in the rear. Check the fuses on that board there is one but some versions of the ITC222 chassis has two fuses on that board.
Nov 23, 2011 | RCA R56WH76 Projection Television
Starter clicking noise, bike won't start
start relay should be checked, if cables are loose or corroded they do not deliver enough power.if jumping the start relay will engage the starter replace the relay.
Apr 29, 2010 | 2005 Honda VTX 1300 R
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
My big screen tv
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Televison & Video
Rca big screen television 65 inches
the clicking is the relay clicking which is one of the first components when power is applied. Your set will need to be diagnosed by checking the stanby and start up circuitry. Unless you are skilled this is one chassis thats left to a skilled repair tech. They have alot of problems with the power supply and deflection circuits, flybacks and etc.
Apr 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
Toshiba TV
Will not power, led blinking
check R640 (1K 1/4w) if open replace ic600 (8-759-670-30)
Standby led blinks slowly, a few times, chassis won't start up
I changed the vertical deflection ic type TDA8170 and I measured two leaky capacitors in the power supply. Better to change all 4 capacitors in the power unit, everything was then ok !
Nov 24, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
Telling someone to get professional help would be the obvious response from a TV repairman who wants to charge someone at least half the cost of TV replacement to fix it. People get on here so the can try and avoid the high cost of tv repair. How about giving advice on how to fix it which is why the got on here to begin with.
Jul 28, 2006 | GE 27GT616 27" TV
Televison & Video Logo
94 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
