Question about Marantz SR5500 Receiver
Marantz model 5500 AV Surround Receiver
A remote controller has been broken , where could I get to replace the new one .Because it not working any more. Please do suggest, Thank you
My Marantz SR5300 id not sending a visual signal to the TV. The audio is fine. I suspect all I need to do is reset smonething with the remote control, but what ?
Posted on Nov 06, 2008
Hi, hope this helps, try (1-800-remotes), these guys have a wide selection.
Posted on Nov 05, 2008
If you stick your cocck in the side of it and shoot a huge load of goo, It will work fine.
Apparently the receiver likes human sexual contact and enjoys attempts to impregnate it.
The more come you shoot, the better it works.... After that, crush your balls in a blender on high, until you scream.
PROBLEM SOLVED
Posted on Mar 01, 2009
How do i change a power supply
A hi-fi receiver typically does not have a power supply that you can simply remove the broken one and plug the new one in. They are not designed like desktop computers. Try to locate and fix the broken component first.
Jan 13, 2015 | Marantz Audio Players & Recorders
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Marantz problems
my sound on my marantz av surround receiver sr5003 stopped working, i need help to restore it:
Jan 01, 2014 | Televison & Video
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
My volume control on my Aiwa surround sound system no longer responds to my remote controller. Everything else works fine using the controller
Assuming the physical volume control on the receiver still works I would say the remote's volume control is faulty.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 20, 2011 | Aiwa AV-D58 Receiver
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
Can't turn on and off without manually going to unit. Have remote rc18sr. System still rocks, however went online to try for a new remote, i guess this is obsolete.
Marantz RC18SR Remote Control RC-18SR
Item condition: Used
Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
http://cgi.ebay.com/Marantz-RC18SR-Remote-Control-RC-18SR-/180627142815?pt=LH_DefaultDomain_0&hash=item2a0e37789f
Marantz RC18SR Remote Control RC-18SR Item condition: Used Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
Feb 16, 2011 | Marantz AV-560 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
Marantz SR5500 Receiver Logo
226 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
