when i try to start my car on the cold weather don't start to start i have to push the accerater when i try to start my car on the cold weather don't start to start i have to push the accerater
AnonymousDec 20, 2008
My 01 Lincoln Town Cars key won't turn in the ignition. My 01 Lincoln Town Cars key won't turn in the ignition.
You can't post conmments that contain an email address.
The starter won't crank. If nothing happens when you turn the ignition key to the "Start" position, it means that the starter motor doesn't turn over the engine. Most commonly this could be caused by a dead battery; here is How to check the battery. ... The starter motor itself or a starter solenoid could be bad.13 Aug 2013
hi, a couple questions. when you turn the key, does anything happen? does the dash light up,does engine turn over, do you hear any clicks from under the hood? without knowing that, its a lil harder to give you a better answer. however,i can give you some info and things to try. first, try jump starting the vechicle. if it starts your batt. is probly where your issue is at. if theres no change, you need to check the resistance of the batt. cables. next, if you can access the starter and solinoid, smack it with a hammer. if it starts ur sol or starter is where your issue is at. hope that helps.
The Water light? you may have over heated the car, also you may have caused a crack in the engine block by driving the car after the Temp light came on, Check the Thermostat, This may have caused the Light to come on and can cause some major problems if not replaced. Good luck!
Several Things
Check For Loose Ground Cable (other end not battery end.
There Is Also A Junction Involved (ground) Where Engine And Body Grounds Come Together--LOOK AT THAT FIRST.
with headlights on, try cranling the engine. I they dim the batt is no good, If they go out, you have a battery connection problem/loose or poor contact on groung(neg) cable. If nothing happens your starter relay is kaput.. Good luck
try to check if the starter relay clicking while you start.If no maybe bad connection from ignition key. If the relay clicking maybe the connection to starter or the starter itself is damaged. try to direct the sol. of starter to batt. positive if it kick your starter is good.
