My Tv 32"(GE-brand)keeps changing channels on it own .. I have unpluged the set overnight for up to ten/hours .. and still the problem. The set is about nine/yrs. old but I'm the only user and so the set isn't on all the time. I even unpluged the VCR and still the problem exist .. the remote is only one/yr. old so that can't be the problem or is it? Please help.
  • 6 more comments
  • larry2439 Oct 22, 2008
    Kevin didn't help out at all.
    still need help with my tv problem
    Have no ideal what this person is trying to say ... English only Please!
    the remote is not the problem as the tv still changes channel when turned on manually.
    What a waste of my time and money ... this is a technical support site correct? Please don't tell me that the advise which I'm getting is from want-to-be's!
  • larry2439 Oct 23, 2008
    butoxige didn't have much to say that the others --NON-TECHNICIANS-- OFFERED. I would like it if a real television techical support person female/male could help me out with this problem ... so that when I do call a repair person I will have at least sonething to being to the table and hopefully not get sent to the cleaners!
    Thanks in advance.
    kagebunshin Thanks for the advise ... I was afraid that a new set was in the works. Better to put the money to something new and with a warranty.
  • larry2439 Oct 24, 2008
    The GE service model no. is 32GT660YX1 ... will be calling a service repair 10/24/08.
    larry2439@msn.com
  • 94 Answers
Are you sure that there is no button stuck on your TV? Kindly check it.
Well, it is probably the controller circuitry. Probably an IC chip gone south or the voltage regulator that is feeding it. Some testing by a tech who knows what he is doing is necessary to check what has failed. Repair could be upwards of $100. Most tv shops will not take in a set this old because support is no longer available for them. If it turns out to be a voltage regulator or power supply problem it can be repaired with generic parts, but if the controller IC has gone bad it may be impossible to find a replacement chip.
As a rule, any tv of this size over 9 years of age is not worthy of repair; better to put the money towards a new set.
Posted on Oct 23, 2008
  • 77 Answers
Other than what melnavz said, the only other thing that comes to mind is the tv is getting interference from another source (this is highly unlikely) but its a suggestion. My advice is either to call GE and see if they will service the tv or call a repair guy, get him to look at it and give you an estimate. The other people have pretty much pointed out any other problems that it might be.
Posted on Oct 22, 2008
    Genius:
  • 1,226 Answers
Your Tv got sticky in the switch or got rust in the board. please open the tv and verify the button switch and blow it air blower. Also verify your remote got clogged when point the remote to the TV it automatically change the channel.
may this help,
melnavz
    Genius:
  • 1,913 Answers
U have to change channel changer circuit.
    Genius:
  • 1,847 Answers
Take out the batteries of all the remotes that are able to change the channel and put a piece of duct tape over the infared reciever and if it still does it, it is most likely defective.
  • Legin Varghese
    Legin Varghese Oct 22, 2008
    if that doesn't work try disconnected the front buttons of my set. Pop off the speaker cover and
    note which color wires come off the buttons and then take off the lower
    back and you can see where it connects to a board. Generally the far
    right connection but trace the wires. After doing that my channels quit
    cycling and everything but the front buttons work.
  • 19,396 Answers
I am a technician.
Remove batteries from remote, to see if the problem is the remote. In that case I can find a replacement remote.
If you have channels changing on their own, then it is a fauty switch, probably a short or a stuck button, if your model has buttons. Otherwise is a faulty control board.
Post exact model if you want more technical support.
The channels on my ge 32gt720 tv keep changing by them self
Channel change button on the remote or on the side of the TV coule be stuck.
Jul 20, 2014 | GE 32GT720 32" TV
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
2005 32-inch GE color television--the problem is all of a sudden the television turned on by itself and started changing channels like crazy--we cannot stop it. When you first turn on the television--it...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 22, 2017 | GE 32GT720 32" TV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Screen is frozen and displaying," this is an encrypted channel." I unplugged it for a few hours, turned off and on....what do I do next
hook up your sat/cable box and reset the tuner; place the set into "setup" then: "add channels" the tuner will look for and install active channels
Apr 25, 2009 | iLO 3200 32 in. LCD Television
GE 32GT740 32" TV problem
there are two things that can cause this, 1 there is a muting transistor on the bottom of the PCB that is a surface mount transistor that goes short. this is the channel mute transistor. when you change channels it is designed to mute the static between channel changes. if it shorts then it mutes. 2 the EE-PROM is defective and needs to be replaced. i'de go with the transistor first. if you are unequipped to do this repair have a tech do it.
Mar 02, 2008 | GE 32GT740 32" TV
RCA TruFlat 30-something inch
what chassis is in your set.look on rear panel ./st
Dec 09, 2007 | RCA 32F530T 32" TV
Sony trinitron tv KV-32LS36U changing channels
You may have a control button sticking either on your remote or on the front panel of your set. I have run in to this on several sets. When this happens, some really strange things will happen including problems like you're having. Stargazer
Jun 13, 2007 | GE 32GT660 32" TV
Sony kv27fv300 changes channels by itself?
Try unplugging your TV for 8 hours and it comes back to normal. At least it did with mine.
Mar 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Open Questions:
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
