Question about RCA RTD207 System
RCA RTD 207 Power light but no power
The power/standby light comes on when the unit is plugged in but that's it, nothing more. Both fuses are good. Nothing looks burned, no odors. What could be wrong? -Brett
  • vernchavez Feb 17, 2009
    I am having the same problem but with the RTD 206. I turn it on but when I push another buttone it says it's doing the command but nothing is happening. It's frozen. HELP!
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: System won't power up
Based on your description, we can limit the fault to the power supply board and in particular to possibly 3~4 components:
  • bridge diode;
  • filter capacitor (mains);
  • regulator;
  • filter capacitor (secondary).
blown fuse indicate a short in any of these.
As Jaime867 has suggested, in the absence of a readily available replacement board, component level might be the best alternative at the moment. Having posted the most likely culprits further narrows down your troubleshooting. Could you pls post back the part number of the smaller IC either 4 or 8 pins?
Alternately, pls check for the presence of a VDR, it would look like a coin (often green in color or something else) with 2 pins. They have been known to short out also and cause fuse to blow. One possible indicator is chipped or flaked of one side or a hairline crack on top. If it is chip, there would be a silvery color on the inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 26, 2008
SOURCE: Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
Posted on Oct 11, 2008
e-Guru
  • 3917 Answers
SOURCE: RCA DVD RTD 315 with wrong region
There are several ways to break or change the region code for allowing DVDs to work. Please find one such link provided bellow .
http://www.gromkov.com/faq/faq2004-0063.html
Thanks
Have a nice day.
Posted on Apr 20, 2009
SOURCE: RCA RT2770: Problem: I power the unit on, it shows
Yea,I hate to tell you this but this unit does this to alot of people.Mine did this I called,and they said send it in,and they would fix,I got it back after a little over a month,pluged in the fixed one,and it worked for a short time,and started doing the same thing.My unit is 10 months old,and has been broke or in their possesion for about 3 months.I wouldnt recomend buynig another one!!!!
Posted on Dec 31, 2010
Won't turn on
Unplug the unit , leave it unplugged, after an hour remove the top cover, look for a fuse near where the power cord enters the unit
. it will be near the power transformer and labeled F1 they are usually 4.5amp 125/250v. the reason for powering the unit down and leaving it off is to let the power capacitors bleed off.some fuses are in holders and some solder in. Hope this helps. If the unit has a bar code anywhere on it you can read the bar code with an app for cell phones and get all the info there. Also try schematicsunlimited.com
Apr 29, 2014 | RCA RTD615I 5.1 Home Theater System - 600...
32 inch rca getting power, but wont turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_29_2012_3_02_02_pm.jpg
left one is good and right one is bad.
Arrows point to bad ones
May 28, 2012 | RCA 32la30rq 32 Tv Black 720p Lcd - - RCA
Samsung LN40C610N1F. When plugged in, the red standby light comes on, but when I hit the power button the unit will not power on. The light doesn't blink or anything.
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_3_53_26_pm.jpg
if set opened look for puffed up caps like these on the power board.
Apr 18, 2012 | Samsung 40 LN40C610 LCD TV
Nothing Happens when I push power
RCA? does the power light/indicator come on and stay on?
a general answer:
ISSUES:
Answers to issues:
Mar 23, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
No Power on rt2580
According the parts list on the model unit your fuse is suppose to be F101,FUSE 6A 125V. Is it possible that you have an undersized fuse?
I don't believe that one amp differents would cause your unit to blow like that but, you never know. More than likely you have a bad component in the power supply or power amp.
Then again, with an average replacement cost of $150 online; it not worth getting too deep into the repairs.
Jan 29, 2009 | RCA RT2500 System
Only standby light comes on
Its been happening a lot to this type of systems from RCA I unplug mine and it starts working(sometimes) Im going to retun the darn thing.
Jun 06, 2008 | RCA RTD255 System
Jun 06, 2006 | RCA RT2500 System
RCA RTD207 System Logo
65 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
