Question about Garden
Tecumseh 4.5hp small engine timing alignment
Engine is on a Craftsmen Yard Vac.Removed base plate to replace gasket and the camshaft fell out.I see a mark on the cam gear but not on crank or crank gear.I Need to know proper alignment ,also on the bottom of the camshaft there is a plastic "banjo" shaped piece with a steel rod with ball end on it,It appears to be there to pump oil thru the camshaft,where it slides over the cam one side is tapered in,the other flat,which side goes toward the base plate? Lastly, any special alignment for the governor gear?
  • LANDON DEAL Mar 03, 2009
    I HAVE TAKEN IT APART SEVERAL TIMES BUT I CAN'T figure OUT HOW TO ALIGN THE CAM SHAFT THE RIGHT WAY CAN ANYBODY TELL ME HOW? E-MAIL ME AT DEALLANDON@YAHOO.COM. THANKS...
  • 48 Answers
The banjo part is the pump - this should be a two piece unit - you will see a cutout in the base plate where the ball end fits into - by tipping the engine upside down while installing base plate you can manuver the ball into place - as far as the crank gear mark one tooth may look different then the rest or have a line on it . it has to be there also as far as the tapered banjo part it realy doesnt matter which way the taper faces
Posted on Oct 23, 2008
On a 1985 f150 where would a camshaft sensor be
Check this procedure... REMOVALand& INSTALLATION
6-300
  1. Remove the grille, radiator, and timing cover.
  2. Remove the distributor, fuel pump, oil pan and oil pump.
  3. Align the timing marks. Unbolt the camshaft thrust plate, working through the holes in the camshaft gear.
  4. Loosen the rocker arms, remove the pushrods, take off the side cover and remove the valve lifters with a magnet.
  5. Remove the camshaft very carefully to prevent nicking the bearings.
  6. Oil the camshaft bearing journals and use Lubriplate or something similar on the lobes. Install the camshaft, gear, and thrust plate, aligning the gear marks. Tighten down the thrust plate. Make sure that the camshaft end-play is not excessive.
  7. The last item to be replaced is the distributor. The rotor should be at the firing position for no. 1 cylinder, with the timing gear marks aligned
V6 and V8 Including Diesel
Ford recommends removing the diesel engine for camshaft removal.
  1. Remove the intake manifold and valley pan, if so equipped.
  2. Remove the rocker covers, and either remove the rocker arm shafts or loosen the rockers on their pivots and remove the pushrods. The pushrods must be reinstalled in their original positions.
  3. Remove the valve lifters in sequence with a magnet. They must be replaced in their original positions.
  4. Remove the timing chain/gear cover and timing chain (timing gear on V8 diesel) and sprockets.
  5. In addition to the radiator and air conditioning condenser, if so equipped, it may be necessary to remove the front grille assembly and the hood lock assembly to gain the necessary clearance to slide the camshaft out of the front of the engine. On the V6-3.8L, remove the camshaft thrust button and spring. Remove the camshaft thrust plate attaching screws and carefully slide the camshaft out of its bearing bores. Use extra caution not to scratch the camshaft lobes.
Camshaft removal tools, Ford part no. T65L-6250-A and adaptor 14-0314 are needed to remove the diesel camshaft.
  1. Coat the camshaft with engine oil liberally before installing it. Slide the camshaft into the engine very carefully so as not to scratch the bearing bores with the camshaft lobes. Install the camshaft thrust plate and tighten the attaching screws to 9 - 12 ft. lbs. Measure the camshaft end-play. If the end-play is more than 0.009 inch; (0.228mm), replace the thrust plate. Assemble the remaining components in the reverse order of removal.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | 1985 Ford F150
Need the timing marks for a 2000 alero
please let me know if you have questions.
2.4L Engine
NOTE It is recommended that the entire procedure be reviewed before attempting to service the timing chain.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following: Negative battery cable, Coolant surge tank, Accessory drive belt, Alternator
  4. Install an engine support.
  5. Remove or disconnect the following: Upper cover fasteners, Front cover vent hose, Right engine mount and bracket, Right front wheel, Right lower splash shield, Crankshaft balancer, Lower cover fasteners, Front cover
  6. Rotate the crankshaft clockwise, as viewed from front of engine (normal rotation) until the camshaft sprocket's timing dowel pin holes align with the timing chain housing holes. The crankshaft sprocket mark should align with the engine mark. The crankshaft sprocket keyway should point upward and align with the cylinder bores centerline. This is the normal timed position.
  7. Remove the timing chain guides.
  8. Remove the timing chain tensioner.
    NOTE Be sure all the slack in the timing chain is above the tensioner assembly when removing it. CAUTION The tensioner plunger is spring loaded and could fly out causing personal injury.
  9. Remove or disconnect the following: Timing chain, Camshaft sprockets
To install:
  1. Install or connect the following: Camshaft sprockets. Torque the bolts to 52 ft. lbs. (70 Nm),
    Camshaft sprocket alignment pin through the camshaft sprockets holes into the timing chain housing holes to position the camshafts for timing.
  2. If the camshafts are out of position and must be rotated more than 1 / 8 turn in order to install the alignment dowel pins, perform the following:
    1. Rotated the crankshaft 90 degrees clockwise off Top Dead Center (TDC) in order to give the valves adequate clearance to open.
    2. Once the camshafts are positioned and the dowels installed, rotate the crankshaft counterclockwise back to TDC.
      WARNING Do not rotate the crankshaft clockwise to TDC or valve and piston damage may occur.
  3. Install the timing chain over the exhaust camshaft sprocket, around the idler sprocket and around the crankshaft sprocket.
    Fig. Timing chain and sprocket alignment positions-2.4L DOHC engine
  4. Remove the alignment dowel pin from the intake camshaft. Using a dowel pin remover tool, rotate the intake camshaft sprocket counterclockwise enough to slide the timing chain over the intake camshaft sprocket. Release the camshaft sprocket wrench. The length of chain between the 2 camshaft sprockets will tighten.
    NOTE If properly timed, the intake camshaft alignment dowel pin should slide in easily. If the dowel pin does not fully index, the camshafts are not timed correctly and the procedure must be repeated.
  5. Leave the alignment dowel pins installed.
  6. With slack removed from chain between intake camshaft sprocket and crankshaft sprocket, the timing marks on the crankshaft and the cylinder block should be aligned. If marks are not aligned, move the chain 1 tooth forward or rearward, remove slack and recheck the marks.
  7. Tighten the chain housing to engine stud. The stud is installed under the timing chain. Torque it to 19 ft. lbs. (26 Nm).
  8. Reload the timing chain tensioner as follows:
    1. Form a keeper from heavy gauge wire.
    2. Slightly, compress the shoe plunger and insert a small screwdriver into the access hole.
    3. Release the ratchet pawl and compress the plunger completely into the hole.
    4. Insert the keeper between the access hole and the blade.
  9. Install or connect the following:
    Tensioner assembly to the chain housing. Torque the bolts to 89 inch lbs. (10 Nm). Tensioner shoe and retainer. Torque the bolts to 89 inch lbs. (10 Nm). NOTE Recheck plunger assembly installation. It is correctly installed when the long end is toward the crankshaft.
  10. Remove the alignment dowel pins. Rotate crankshaft clockwise 2 full rotations. Align the crankshaft timing mark with mark on cylinder block and reinstall alignment dowel pins. Alignment dowel pins will slide in easily if engine is timed correctly.
    WARNING If the engine is not correctly timed, severe engine damage could occur.
  11. Install or connect the following: Timing chain guides, New seal into the front cover by lubricating the seal lip and tapping it into place, Front cover and gaskets. Torque the nuts and bolts to 106 inch lbs. (12 Nm), Crankshaft balancer. Torque the bolt to 129 ft. lbs. (175 Nm), Right front lower splash shield, Front wheel. Torque the nuts to 100 ft. lbs. (140 Nm), Right engine mount bracket. Torque the bolts to 81 ft. lbs. (110 Nm) plus an additional 90 degree turn, Right engine mount. Torque the bolt to 49 ft. lbs. (60 Nm), Upper cover vent hose
  12. Remove the engine support.
  13. Install or connect the following: Alternator. Torque the bolts to 37 ft. lbs. (50 Nm), Accessory drive belt, Coolant surge tank, Negative battery cable.
  14. Refill the cooling system.
  15. Start the engine and check for leaks.
Oct 04, 2011 | Cars & Trucks
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I would like to have a diagram of the timing comfiguration of a 2002 dodge intrepid 2.7 .....i am very interested in the timining marks for the camshafts
Hi, this engine uses plated links in the chain to match marks on the gears. See figure and installation procedure below. Let me know if you have any questions and thanks for using FixYa.
    1. Install the timing chain by performing the following procedure:
    1. Verify that the crankshaft sprocket timing mark is aligned with the mark on the oil pump housing.
    2. Place the left side primary timing chain sprocket onto the chain, while aligning the timing mark on the sprocket to the 2 plated links on the chain.
    3. Lower the chain with the left sprocket through the left cylinder head opening.
    4. Loosely position the left camshaft sprocket over the camshaft hub.
    5. Align the plated link to the crankshaft sprocket timing mark.
    6. Position the timing chain around the water pump drive sprocket.
    7. Align the right camshaft sprocket timing mark to the plated link on the timing chain and loosely position the sprocket over the camshaft hub.
    8. Verify that all the plated links are aligned to their proper timing marks.
    1. Install the left lower timing chain guide and tensioner. Torque the bolts to 21 ft. lbs. (28 Nm).
      NOTE Inspect the timing chain guide access plug O-rings before installing. Replace damaged O-rings as necessary.
    2. Install the timing chain guide access plug to the left cylinder head and torque to 15 ft. lbs. (20 Nm).
      NOTE To reset the timing chain tensioner, oil will first need to be purged from the tensioner.
    1. Purge oil from the timing chain tensioner using the following procedure:
    1. Remove the tensioner from the tensioner housing.
    2. Place the check ball end of the tensioner into the shallow end of the Tensioner Resetting Special tool 8186.
    3. Using hand pressure, slowly depress the tensioner until oil is purged from the cylinder.
    4. Reinstall the tensioner into the tensioner housing.
    1. Reset the timing chain tensioner using the following procedure:
    1. Position the cylinder plunger into the deeper side of the Tensioner Resetting special tool 8186. Apply a downward force until the tensioner is reset.
    WARNING
    Ensure that the tensioner is properly reset. The tensioner body must be bottomed against the top edge of the Tensioner Resetting Special tool 8186. Failure to properly perform the resetting procedure may cause tensioner jamming.
    1. Install the chain tensioner into the right cylinder head.
    2. At the right cylinder head, insert a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    3. Turn the left camshaft by inserting a 3 / 8 in. square drive extension with a breaker bar into the intake camshaft drive hub. Rotate the camshaft until the camshaft hub aligns with the camshaft sprocket and damper attaching holes. Install the sprocket attaching bolts and torque to 21 ft. lbs. (28 Nm).
    4. If necessary, rotate the engine slightly clockwise to remove any slack in the timing chain.
    5. To arm the timing chain tensioner: Use a flat-bladed prytool to gently pry the tensioner arm towards the tensioner slightly. Then, release the tensioner arm. Verify the tensioner extends.
    6. Inspect and replace the timing chain cover gasket and oil seal.
    7. Apply a 1 / 8 in. (3mm) bead of sealer at the parting line of the oil pan and engine block.
      NOTE When installing the timing cover, guide the seal over the crankshaft to prevent damage to the seal-s lip.
    Timing cover and gasket and torque the M10 bolts to 40 ft. lbs. (54 Nm) and the M6 bolts to 105 inch lbs. (12 Nm)
    Accessory drive belt tensioner pulley
    Power steering pump
    Crankshaft damper
    Crankshaft center bolt and torque the bolt to 125 ft. lbs. (170 Nm) using tool 8191
    Accessory drive belts
    Fan module and electrical wiring harness
    Upper radiator crossmember
    Dec 25, 2010 | Dodge Intrepid Cars & Trucks
    Como poner la banda de tienpo de un toyota camery
    Installation
    1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
    CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
    4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
    CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
    9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
    Dec 23, 2010 | 1993 Toyota Camry V6
    How to change time chain on a 3.3 v6 dodge caravan, easy way to look at timeing chain, so i can tell if it is bad
    This design has no tensioner. Check the sprockets for wear on the tips--especially the crank sprocket. With the cover off, turn the crankshaft with a socket and see how close the chain comes to slipping backward on the sprocket. There are complete replacement procedures at AutoZone.com, which I will try to paste in below.
    3.3L and 3.8L Engines
    See Figure 18
    0900c15280215ddb.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 18: Timing mark alignment-3.3L and 3.8L engines
    1. If possible, position the engine so that the No. 1 piston is at TDC on the compression stroke. Disconnect the negative battery cable. Drain the coolant.
    2. Remove the timing chain case cover. For more information, refer to the Front Timing Cover and Seal procedure, earlier in this section.
    3. Remove the camshaft gear attaching cup washer and remove the timing chain with both gears attached. Remove the timing chain snubber.
    To install:
    1. Assemble the timing chain and gears.
    2. Turn the crankshaft and camshaft to line up with the key way locations of the gears.
    3. Slide both gears over their respective shafts and use a straight edge to confirm alignment.
    4. Install the cup washer and camshaft bolt. Tighten the bolt to 35 ft. lbs. (47 Nm).
    5. Check camshaft end-play. The specification with a new plate is 0.002-0.006 in. (0.051-0.052mm) and 0.002-0.010 in. (0.51-0.254mm) with a used plate. Replace the thrust plate if not within specifications.
    6. Install the timing chain snubber.
    7. Thoroughly clean and dry the gasket mating surfaces.
    8. Install new O-rings to the block.
    9. Remove the crankshaft oil seal from the cover. The seal must be removed from the cover when installing to ensure proper oil pump engagement.
    10. Using a new gasket, install the chain case cover to the engine.
    11. Make certain that the oil pump is engaged onto the crankshaft before proceeding, or severe engine damage will result. Install the attaching bolts and tighten to 20 ft. lbs. (27 Nm).
    12. Use tool C-4992, or equivalent, to install the crankshaft oil seal. Install the crankshaft pulley using a 5.9 in. suitable bolt and thrust bearing and washer plate L-4524, or equivalent. Make sure the pulley bottoms out on the crankshaft seal diameter. Install the bolt and tighten to 40 ft. lbs. (54 Nm).
    13. Install all other parts removed during the chain case cover removal procedure and fill the engine with oil.
    14. Connect the negative battery cable, road test the vehicle and check for leaks.
    Aug 29, 2010 | 1993 Dodge Caravan
    How do I time a 2006 dodge caravan 2.4L
    2.4L Engine
    NOTE You may need DRB scan tool to perform the crankshaft and camshaft relearn alignment procedure.
    1. Remove or disconnect the following:
      • Negative battery cable
      • Right front wheel and inner splash shield
      • Accessory drive belts
      • Crankshaft damper
      • A/C compressor/alternator tensioner and pulley assembly
      • Lower front timing cover
      • Upper front timing cover
      • Right engine mount
      • Engine mount bracket
      NOTE This is an interference engine. Do not rotate the crankshaft or the camshafts after the timing belt has been removed. Damage to the valve components may occur. Before removing the timing belt, always align the timing marks.
    2. Rotate the crankshaft until the Top Dead Center (TDC) mark on the oil pump housing aligns with the TDC mark on the camshaft sprocket (located on the trailing edge of the tooth).
    3. Loosen the timing belt tensioner lock bolt.
    4. Insert a 6mm Allen wrench into the hexagon opening located on the top plate of the belt tensioner pulley. Rotate the top plate clockwise until there is enough slack to remove the belt.
    5. If necessary, remove the camshaft timing belt sprockets.
    6. If necessary, remove the crankshaft timing belt sprocket using removal tool No. 6793, or equivalent.
    7. Place the tensioner into a soft-jawed vise to compress the tensioner.
    8. After compressing the tensioner, insert a pin (a 5/64 in. Allen wrench will also work) into the plunger side hole to retain the plunger until installation.
    Camshaft and crankshaft alignment marks—2.4L engine
    To lock the timing belt tensioner, be sure to fully insert the smaller Allen wrench into the tensioner as shown—2.4L engine
    Installation of the timing belt, notice the camshaft alignment— 2.4L (VIN B) engine
    To install:
    1. If necessary, use tool No. 6792, or equivalent, to install the crankshaft timing belt sprocket onto the crankshaft.
    2. If necessary, install the camshaft sprockets onto the camshafts. Install and tighten the camshaft sprocket bolts to 75 ft. lbs. (101 Nm).
    3. Set the crankshaft sprocket to Top Dead Center (TDC) by aligning the notch on the sprocket with the arrow on the oil pump housing.
    4. Set the camshafts timing marks so the exhaust camshaft is 1/2 notch below intake camshaft sprocket. Make sure the arrows on both camshaft sprockets are facing up
    5. Install the timing belt starting at the crankshaft, then around the water pump sprocket, idler pulley, camshaft sprockets and around the tensioner pulley.
    6. Move the exhaust camshaft sprocket counterclockwise to take up the belt slack.
    7. Insert a 6mm Allen wrench into the hexagon opening located on the top plate of the belt tensioner pulley. Rotate the top plate counterclockwise until there is no slack on the belt. The tensioner setting notch will start to move clockwise. Watch the notch and continue rotating the top plate counterclockwise until the setting notch is aligned with the spring tang. Using the Allen wrench to prevent the top plate from moving, tighten the tensioner lock bolt to 220 inch lbs. (25 Nm). The setting notch and spring tang should remain aligned after the lock nut is tightened.
    8. Rotate the crankshaft 2 revolutions and recheck the timing marks.
    9. Check the spring tang is within the tolerance window. If not within the window, reinsert the Allen wrench and into the hexagon opening located on the top plate of the belt tensioner pulley. Rotate the top plate counterclockwise until there is no slack on the belt. The tensioner setting notch will start to move clockwise. Watch the notch and continue rotating the top plate counterclockwise until the setting notch is aligned with the spring tang. Using the Allen wrench to prevent the top plate from moving, tighten the tensioner lock bolt to 220 inch lbs. (25 Nm). The setting notch and spring tang should remain aligned after the lock nut is tightened.
    10. Install the engine mount bracket.
    11. Install the front timing belt covers.
    12. Install the A/C compressor/alternator tensioner and pulley assembly.
    13. Install the right engine mount.
    14. Install the crankshaft damper
    15. Install the accessory drive belts and adjust to the proper tension.
    16. Install the right inner splash shield and wheel.
    17. Reconnect the negative battery cable.
    18. Perform the crankshaft and camshaft relearn alignment procedure using the DRB scan tool, or equivalent
    Please do not forget to rate and comment about your experience with fixya today... If there is any further assistance i can provide for you please let me know..
    Dec 28, 2009 | 2006 Dodge Caravan
    TIMING MARKS CAMBELT REPLACEMENT FOR CL-T CHARADE, PLEASE
    This is the best I could find for you .. I am unfortunately able to verify the info because I have no personal experience with this car or its engine ...
    Mar 14, 2009 | 1988 Daihatsu Charade
    Need instructions to replace 1993 Toyota Camry Timing Belt
    Hi Kmcarroll77
    TIMING BELT REPLACEMENT - 2.2L -1993 Toyota Camry
    Installation
    9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence. See Fig. 6 . On MR2, tighten engine
    Hope this helps, don't forget to rate.
    Lazaruselite
    Feb 25, 2009 | 1993 Toyota Camry V6
    the crank gear has a marked tooth and the cam has a mark between two of the teeth - the other piece is the govener gear which meshes on the cam - it must be aligned so it contacts the gov arm - without a mod # im not sure which style gov gear you have . there is no oil pump in an engine of that size
    Oct 21, 2008 | Garden
    Garden Logo
    1,422 people viewed this question
    Top Garden Experts
    EugenesDIYDen
    EugenesDIYDen
    Dennis Key
    Dennis Key
    john h
