Question about Dell Latitude D600 Notebook
Microphone Won't Work
I have an external headphone and microphone set plugged into my Latitude and the headphones work fine but the microphone won't. Previously the microphone worked fine up until a few days ago and now it won't work at all. The drivers are all updated, the sound is not turned off, the microphone is not muted, etc. I've tried all of the regular troubleshooting for this but nothing seems to work. Any suggestions?
    Genius:
  • 1,913 Answers
Check your cpu port for microphone to motherbord.
or may be microphone may be faulty.
Posted on Oct 22, 2008
Dr dre headphones won't work with my portable CD player
Try the Soul By Ludacris. They look nicer and they work http://bestheadphones-review.com/soul-by-ludacris-sl300wb-high-definition-noise-canceling-headphones-review/
Jan 20, 2013 | HP Beats By Dr. Dre Solo Headphones,...
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Headphones for a laptop not working
click on Sound
select that!!
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Under device manager where to locate microphone option
Your microphone would only show up under Device Manager if it is a USB microphone. If you are using analog, 2.3mm jack (looks like a headphone jack only red), then you won't see it there.
For WinXP you want to be looking under Control Panel, Sounds and Audio Devices to see and configure settings for your speakers, microphone, etc.
What is shown under Device Manager, if you aren't using a USB microphone, is the sound card. This is because your headphone and microphone ports are connected to the sound card in your computer.
Jul 06, 2012 | Computers & Internet
Hello there, my mic won't work.
The external microphone input is most likely dirty and causing the internal microphone connection to be disconnected. The mic socket is at the front edge next to the headphone socket. try cleanig with a vacuum cleaner first to clear any dust and fluff. Then use a cotton bud and cleanig fluid e.g. WD40 or contact cleaner, or CD cleaning fluid.
May 26, 2011 | Nintendo DS Lite Console
My built in microphone on my laptop is not working, i want to download a built in microphone maybe it can solve my problem
have your sound it's ok ? if your sound driver was installed and correct running normally, your microphone can to use, if not you must install your driver for sound
Mar 18, 2011 | Computers & Internet
Microphone of Dell latitude D610 not working
The D610 has two audio jacks. The one closest to the monitor has a picture of a microphone above it, and the one closest to the user has a picture of headphones above it. Do you have your microphone plugged into the correct jack?
Aug 28, 2010 | Dell Latitude D610 Notebook
Losing sound when plug in mic
You are probably plugging the mic in the wrong port, you should plug it in the other port looks the same.
I think the port that you are plugging in your mic is of sound (headphones).
Hope this helps
Mar 30, 2010 | Audio Players & Recorders
Headphones w/ built-in microphone. Can both work with one jack?
the simple answer is No. The long answer is your laptop/computers headphone output and mic input are completely separate on the sound card. Meaning there are no tie to the audio in on the heaphone lines, and vise versa on the mic/line in. Sorry to disappoint.
Sep 17, 2009 | Skull Candy Full Metal Jacket Stereo Ear...
My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Feb 12, 2008 | Toshiba Satellite A135 Notebook
Dell Latitude D600 Notebook Logo
2,511 people viewed this question
Alun Cox
