Question about Pyle PLBINDV7 Car DVD Player
Video disabled Even while parked and the ignition in the acc. position the screen still reads "video disabled while driving for safety purposes". Does anyone know why this might be happening? Thanks in advance, Joe
  • 2 more comments
  • Joe Vinlove Jul 28, 2006
    Actually i figured it out. It turned out that the side brake wire wasn't grounded...lol all better.thanks though
  • aidb Nov 05, 2007
    screen
  • Anonymous Jan 19, 2008
    is there any way of bypassing the ebrake problem ?
  • Anonymous Apr 15, 2008
    same problem, worked in my last car forgot which wires were
    connected to ground/ power. anyone know where you can get wire
    diagram for this unit?
The problem is most likely in the wiring to the ignton switch keyed power line wich will possibly be yellow.How ever To be more percise the wiering diagrams for the car and head unit would be nessary.if this could be supplied an answer would easily be supplied.
Posted on Jul 28, 2006
To bypass any alpine ebrake. u will need to purchase a universal trigger output module better known as a PTR7. posted by Carlos Arce owner and installer of "Arce Audio" of wichita kansas
contact Carlos Arce at (316) 831-9731 for any questions.
operation hours everyday 9am to 7pm.
Posted on Mar 13, 2009
  • 3 Answers
This brake wire, does it need to be attached to the handbrake or something? i installed an alpine dvd deck in a friends car with no diagram.
Posted on Jul 04, 2008
Could u tell what color wire you didnt have connected cuz i have the same problem that u had and sum of my wires are not also hooked up...hit me back at repintexas4life@hotmail.com or just right here thanks
Posted on Jan 20, 2008
  • 3 Answers
Its the green wire.. just connect it to ground, when u put dvd.. if still no pic, click on DISP button in front panel
Posted on Jun 16, 2007
Where is the fuse located that activates the seatbelt alarm for my 2008 mercury mariner.
There is not a single fuse just for the seat belt alarm .
The instrument cluster provides the warning chime function. The instrument cluster uses various inputs to determine when to sound the warning chime. The warning chime sounds if:
  • the headlamps are left on with the ignition switch in the OFF position and the driver door is ajar.
  • the key is in the ignition with the ignition switch in the OFF position and the driver door is ajar.
  • the transaxle is not in the PARK (P) position and the driver door is ajar.
  • a door is ajar while the ignition switch is in the RUN position.
  • the safety belts are not fastened and the ignition switch is in the RUN position.
  • the turn signal is on for more than 3.2 km (2 miles).
  • the parking brake is engaged and the vehicle is moving more than 5 km/h (3 mph).
  • the ignition switch is in the RUN position and a secondary air bag warning chime request is received from the restraints control module (RCM).
  • the ignition switch is in the ON position with the transaxle in the PARK (P) position and the driver door is ajar (Hybrid).
An audible signal is provided to indicate when the turn or hazard signal is on.
Safety Belt Minder Deactivating/Activating
Preparation
  1. Apply the parking brake before deactivating/activating the belt minder.
  1. Place the gear selector lever in PARK or NEUTRAL (manual transaxle).
  1. Place the ignition switch in the OFF position.
  1. Close all the vehicle doors.
  1. Unbuckle the driver safety belt.
  1. Place the parking lamps/headlamps switch in the OFF position.
  1. Turn the ignition switch to the RUN position. (Do not start the engine.)
  1. Wait until the safety belt warning lamp turns off (approximately 1 to 2 minutes).
  1. NOTE: Steps 3 must be completed within 50 seconds after the safety belt warning indicator turns off. For seating position being disabled, at a moderate speed, buckle then unbuckle the safety belt 9 times, ending with the safety belt in the unbuckled state. After this step, the air bar warning indicator illuminates for 3 seconds.
  1. Within 10 seconds after the air bar warning indicator turns off, at a moderate speed, buckle then unbuckle the safety belt.
    • This disables the safety belt minder feature for that seating position, if it is currently enabled. As confirmation, the air bar warning indicator flashes 4 times per second for 3 seconds.
    • This enables the safety belt minder feature for that seating position, if it is currently disabled. As confirmation, the air bag warning indicator flashes 4 times per second for 3 seconds followed by another flash sequence of 4 times per second for 3 seconds.
  1. After confirmation, the deactivation/activation procedure is complete.
Jan 07, 2018 | Mercury Mariner Cars & Trucks
How do you make the cigarette lighter power on a 2008 Chevrolet equinox shut off when you turn the key off?
For safety purposes it only work when the ignition switch is positioned to ACC or to ON.
Aug 29, 2014 | 2008 Chevrolet Equinox LS
Sometimes after I put my 2000 Buick Regal LS in Park and turn off the engine the ignition switch not the key gets stuck in the on and acc position. What causes this to happen?
Replace ignition switch (the tumbler portion) seems like its hanging up, and you shouldn't be able to remove the keys unless the switch is off.The park safety switch possibly. This switch tells the vehicle its in Park. Hope this helps.
May 26, 2014 | 2000 Buick Regal LS
Why when playing my dvds the screen turns blue and says screen disabled for your safety?
Your parking brake wire is either not correctly installed or your parking brake is not engaged. It is illegal to drive while watching video so the player will disable video if you are not parked.
Jul 12, 2012 | Pyle PLDN73I Car Video Player
I Can't see Video,,,,,,,,when I insert a DVD in the Radio it Shows me a Screen (This feature is not available when Driving)
press and hold the volume button for 10 seconds. in that menu somewhere you will find something about a park safety switch or park mode. stereos come with that turned on from factory. you can disable in the menu. Let me know how that works out for you and if you could rate my assitance! thanks!
May 12, 2011 | Pyle PLTS75 Car DVD Player
Key stuck in my 2006 Buick Lacrosse I can start and drive the car but can't remove the key after turning off the engine without pushing the release button which is at the bottom of the steering colum. I do...
bad battery and if i don't drive the car couple of days then it goes dead ??? It's not the battery , you have a parasitic draw on the electrical system , that is what is draining the battery . Could be the instrument cluster .Watch this video . What's giving out 13 volts or when ? With the engine running hooking a volt meter to the battery the voltage should be 13 - 14 volts , depending on the load on the electrical system.
Chevrolet Truck Battery Dies Overnight Part
Does the vehicle have column or floor mounted gear selector ? Both have a safety feature Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator:
Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
Linear Shift Assembly: If the vehicle is equipped with a column mounted gear shift, it has a linear shift assembly on the steering column. The linear shift assembly has a cable that runs from the linear shift assembly to the ignition lock cylinder case. The purpose of this cable is to prevent the ignition key from being turned to the OFF position when the transmission is in gear and the vehicle may still be moving. The linear shift assembly cable contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
May 05, 2017 | 2006 Buick LaCrosse
Ignition is stuck in run position
does your key stays in the ignition position? or can you turn it back to acc or lock? it might be a stuck ignition switch mechanism inside or a shorted circuit that latches the ignition...have it checked or you can try to open it the switch yourself..but with caution if this is your first time. Pls give me a feedback. thanks!
Aug 19, 2009 | 2008 Chevrolet Cobalt
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Feb 25, 2009 | 1999 Ford Taurus
I need a copy of teh manual for my 2004 Ford Explorer manual.
Wear your safety belt, or simply unplug the harness located at the seatbelt receptacle.
Jan 13, 2009 | 2004 Ford Explorer
Seat Belt Chime
Preparation
1. Before deactivating/activating the belt minder, set the parking brake.
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. user_offline.gif
Apr 02, 2008 | Car Audio & Video
Pyle PLBINDV7 Car DVD Player Logo
1,088 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
