I have a Standard SD650 or a Ricoh j8500 duplicator with a SC07-30 do you know what is wrong?
SC07-30 Friction pad motor lock. Defective sensor or motor.
Posted on Oct 22, 2008
Smith Corona SD650 Model 5A Ribbon
This takes an "H" series ribbon SCM #21000
DickyO
Apr 10, 2013 | Smith Corona Typewriter SD650 Refurbished...
Whats the cause of a blank copy in a copier machine Nashuatec,Ricoh or Gestetner machine
can be several causes.
1-Tansfer rollers or wires broken or not charging.
2- no charge to the drum
3-laser unit --could be the shutter not opening or bad laser(should give a code if bad laser)
4-Developper not charging and transferrring toner.
If you can open machine and cheat door to make copier run, make a copy and stop paper as it gets to drum you should see toner on the drum. If there it is not transferring to the paper problem should be the transfer roller or wires(directly under drum. ) If not you need a tech to determine which one is not working.
Sep 05, 2012 | Standard Registar SD650 Color Copier
Ricoh Aficio 1013f is duplicating print under each line. Happens on copying, printing and faxing. Have changed process drum unit twice in the last year, fuser unit and had unit cleaned. Was better for...
What type of environment is this copier in? Standard office, warehouse, etc. If the temperature in the area fluctuates a lot, that could have something to do with your problem. Usually ghosting problems like that originate in the fuser. Try increasing or decreasing the fuser temperature to see if that fixes the issue.
Aug 10, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
I have a Konica 7030 photocopier. f-26-1 code came up what does this mean we had just changed the toner cartridge pls adv
F 26 IS RELATED ON DEVELOPER UNIT. TRY TO CALIBRATE THE DEVELOPER USING 47 MODE SUB 25,AND LET THE MACHINE RUN FOR 10 MINUTES
Nov 26, 2008 | Standard Registar SD650 Color Copier
Standard Try Full
'Standard tray full, remove paper' is the output tray where the prints exit.
Check also the exit sensor/feeler condition.
Good luck and please rate me, thanks.
Sep 05, 2008 | Ricoh Aficio SP C811DN-DL Printer
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
104 people viewed this question
jasbo
jasbo
