Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-Aire Electric Range Oven will not preheat, getting F0 code.
Our drop in Jenn-Aire Electric Self Cleaning Down Draft Range will not preheat making the baking and broiling inoperable. However, the 4 burners on the stove work fine. Until now if I kept repeating the bake selection the preheat would finally work. Today, when I tried the code F0 appeared on the display and the oven started beeping. I canceled immediately as I wasnt sure what the code stood for. Can you tell me what the code represents and or what I can do to get the oven going? The range
SOURCE: Installation of down-draft exhaust duct for Jenn-Aire cook top
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
SOURCE: clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Posted on Jun 02, 2008
  • 2692 Answers
SOURCE: 1985 jenn air electric range
http://www.jennair.com/customer_care/contact_us.jsp
Posted on Dec 29, 2008
  • 93 Answers
SOURCE: oven will not heat
ok few things sound like the gas valve may be turned off what i mean about turned off is at the gas valve contro;l normally installed under the stove on the left side of the valve tere is a verry small lever that serve as a shut of vave i have seen those lever in plastic normally red it may have sticked it self close or fallen out check on the floor if you do not see any small parts another thing check for fuse also there is a solenoid valvve that possibly not opening up one more thing does your stove connect to a normall 120 volt plug or does is connect to your 220 volt electric stove plug with a adapter if so check your breakers thanks gilles_dumais@hotmail.com
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: Jenn-Air Range: I am getting an F0 error.
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
Posted on May 29, 2009
After cleaning oven door won't unlock . it is a jenn aire oven
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 09, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-aire s176 electric oven will not hold set temperature
Sounds like you have a bade temp sensor.Have a great Thanksgiving.
Nov 25, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn aire down draft electric glass top
go to jenn air web site find your stove , find users manual or use and care guide- there should be an answer there for you--
Mar 21, 2009 | Kitchen Ranges
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Aire locked tight!
that relay/solenoid can get stuck quite easily..
you have a service contract on this?
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Clock assembly
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn-Air slide-in range with a gas top and electric oven. I have tried to clean the gas grates without much success. I have also tried to clean my white exhaust cover for the down-draft. It has...
i would NOT recommend putting grates in oven while self cleaning, dont even leave the racks in there!!!! ammonia supposedly cleans them pretty good, get yourself a plastic garbage bag and a measuring cup full of ammonia. place the grates in the bag and stand the cup up in the bag with them, close the bag and place on the back stoop over night. the FUMES do all the heavy work you rinse off under the sink.DO NOT pour over the grates but stand up the cup next to them.make sue to seal the bag as well!!!
Mar 08, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
71 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
