Question about Goodman GMS90703BXA Heater
Blower will not turn off
When the heat turns off, the blower does not stop running.
    Problem Solver:
  • 7 Answers
There is a fan switch that senses the temperature in the heat chamber that turns the blower on when reaches temperature and off when it cools down enough sounds like it went out. should be black cover or metal box on front of chamber with wires going to it. good luck
Posted on Oct 25, 2008
If I shut off the blower on my gas furnace do I have to shut down the whole furnace
Turn of the system at the thermostat. If you turn off the blower, assuming you mean at the tstat, there's no need to turn off the pilot. If blower is running and won't stop, even if turned off at tstat, turn off power by any means necessary, and pilot does not need to be turned off. A "standing pilot" is made to stay lit at all times, running or not.
Mar 07, 2017 | Heating & Cooling
Blower (a/c & heat) stopped working on 2008 Pontiac Vibe. No heat or a/c.
Could be a bad connection at one of the fuses, or a coincidence and has nothing to do with the fuses. It could be the blower motor, resistor, or a connection somewhere.
You would need to check the blower fuse for power with a meter and then the blower motor when it fails to run.
Feb 11, 2014 | Cars & Trucks
Intertherm e2eb 015ha
let me guess.....its electric, right? could be so many things! do this first. turn power off. check all wiring for burnt or broke wires., usually at connections. next turn system on. does blower stop running and then breaker trips? if so its blower motor or blower relay. if blower and wires are ok then problem is probably a broken heating element.
Jan 25, 2014 | Heating & Cooling
Unit turns on but doesn't stay on
If you have a non digital type of thermostat and a gas furnace, it will have an adjustable anticipater as part of the thermostat. In a normally operating system the average anticipater setting is 0.4 amps. Or simply .4 . Incorrect setting can cause the heat to turn off early or late.
If the burners are staying on but the blower turns off you could have a faulty blower motor. Sometimes replacing a faulty blower motor run capacitor will extend the operational life of the motor.
There a many other possibilities.
Dec 12, 2013 | Ruud UBHC Air Conditioner
Furnace won't stop running
Jump out limit switch blower should stop and inducer should come on then the heating sequences should start from there
Nov 28, 2013 | Carrier 52CQ-312-4 Comfort Series Heat...
2002 cavalier, heat but blower not running
you may have a bad blower motor or bad resitor
Jan 24, 2013 | 2002 Chevrolet Cavalier Coupe
Fan for heat turns on and off and sometimes stays off
If it comes and goes on all speeds, I would say its probably the blower motor. You would check for power and ground at the blower motor when it stops running.
If its only on one speed, it may be the blower resistor.
Jan 07, 2013 | 2004 Chevrolet Malibu Maxx
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Blower motor runs but dies out..
When it does this carefully feel the end of the blower motor. If it is too hot to touch,Replace the blower motor.
Your 5 minute off sequence allows the motor to cool enough for a restart.
Apr 08, 2009 | Amana PTH153B50AJ Heat Pump Air...
did you check the volts? and the amps.
Apr 08, 2009 | Amana PTH123B25AJ Heat Pump Air...
Goodman GMS90703BXA Heater Logo
78 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
