Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Red Light Hello, the red light will not go off - what could be the problem?
  • 2 more comments
  • Anonymous Nov 24, 2008
    and I noticed that one of the wires was broken.
  • Anonymous Nov 29, 2008
    the red light keeps blinking what does this mean
  • omchiu Dec 29, 2008
    Help i have the same problem
  • shalau Feb 14, 2009
    THE RED LIGHT KEEPS FLASHING
Help..same problem that damn red light..blinks...can you help me
Posted on Dec 06, 2008
Please let me know it happened to me too
Posted on Nov 07, 2008
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Honeywell HHT-011 Air Purifier red light will not turn off even after cleaning the filter three times.
For those who's red light will not turn off after cleaning. There is a little button by the red light indicator. Take a paper clip and hold in for about 5 seconds. Light will then turn off.
Jan 22, 2011 | Honeywell HHT-011 Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 09, 2010 | Filter Queen Defender Air Purifier
Have a red light on in front - looks like something needs serviced. I rinsed the filters that pull out and light stays on. Might be a filter further in the unit or something might need to be reset??? ...
To the left of the little red light is the reset button. It's disguised as another light that isn't on. :) Press and hold it for about 10 seconds and the red light will turn off.
Mar 03, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but  the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Sep 06, 2007 | Filter Queen Defender Air Purifier
Red light
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
Apr 13, 2007 | Filter Queen Defender Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
709 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
