Question about Thermador Pro Harmony PRD304EHU (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Gas pipe manifold pipe size is 3/4 " , should be 1/2 "
II just received this range and IT IS suppose to have a 1/2 " gas pipe for the manifold for the cooktop. The pipe is 3/4 " and I can not fit the 3/4 " fittings in the back without relocating the cooling fan on the range ?
  • 1 more comment
  • geo_cost Oct 23, 2008
    My range came with a 3/4" gas line for the cooktop. The manual states it is
    1/2" . It even comes with a plastic bag taped to the gas line with a 1/2"
    90 degree street elbow inside with instructions that say to use it on the pipe ?
    there is very limited access on the back of this range and it is impossible to use any 3/4" fittings on this range with out removing one of the cooling fans. I do not believe I would be able to reinstall the fan after the fittings would be installed.I can not get a answer from anyone about why it does not have a 1/2" pipe like the manual states. For the money I paid for this range I feel I should not have to relocate cooling fans to hook up a gas line. Does anyone else have this problem or is my range the only one like this?
    I know allabout pipe fitting ect. My problem is why this range has a larger pipe size than the manual states and why I would have to relocate cooling fans to hook up this range? Am I the only one that has this problem ?
    Genius:
  • 2,035 Answers
The manual says the pipe of the internal gas line is 1/2 and the external line 3/4 flex gas line :
Use 3/4" flex line to connect between the gas supply and the appliance manifold
pipe, which exits the upper rear of the appliance on 30” and 36” ranges. The appliance manifold pipe connection is 1/2" NPT. Use caution to avoid crimping the 3/4" flex line when making bends.
Suggested length of flex line is 48";gas pipe manifold pipe size is 3/4
supply and the appliance manifold pipe.
Please click on this link and get the latest installation manual
http://www.bshextranet.com/files/techtoolbox/90002361291.pdf
Good luck.....
gas pipe manifold pipe size is 3/4 moz-screenshot-1.jpg
Posted on Oct 23, 2008
    President:
  • Thermador Master
  • 2,651 Answers
Find it comicall that the last 3 suggestions all though im sure they wanted to help , not an appliance background on any of them.GOOD SHOW!! you state you just recieved this unit??? did you buy it from a dealer new, or aquire it second hand from another source?? without seeing it for myself im takin you word that its sized incorrctly. did you try calling the manufacture ( they would know their product better then anyone and if there is a discrpency they will be able offer you a solution)definatly should not be relocating or unhooking cooling fans to install the unit. 1-800-735-4328
1-800-656-9226
i did download an installation manual, didnt have your model but checked a few and seemed to be the same. asking that you install the supplied pressure regulator, perhaps you didnt install that and thats where the pipe sizing diff is.
    Sergeant:
    Champion:
  • 435 Answers
Hi, I guess you question is how to use these pipes.
You can use manifold pipe adapters/ fittings which can connect pipes of two different sizes.
I can look for one if you can tell me about the pipe. what brand is it? did you get it along with the Cooktop ?
Thanks, :)
Posted on Oct 22, 2008
    Genius:
  • 1,226 Answers
You can buy gas pipe adjuster from 1/2 to 3/4..however you can buy 1/2 gas pipe in any vendor of the range.
gas pipe adjuster is the solution.
melnavz
    Genius:
  • 1,847 Answers
Did you check the manaul for help. I can get you one.
While driving, should I'd overwhelming
Hub bearing get them checked
Mar 10, 2013 | Cars & Trucks
Raptor 660 backfires and pops
Hi mate most common setting on almost all carbs would be 1.5 to 2.5 turns out. if runs better with less turns out than this range, then you need smaller pilot jet, or if needs more turns out then 2.5 you need bigger pilot jet. The glowing red header pipe is normal every yamaha I know will do this especially if left to idle for more than a minute... Regarding issue of popping this nearly always due to lean pilot circuit. first step clean pilot jet and or up size your pilot jet 2 or 3 sizes. just to clarify the turns out procedure make sure you are counting a full 360 degree turn out as 1 turn. I have seen in the past guys adjusting this air/fuel mixer and counting 180 degrees as 1 turn out needless to say it don't work... cheers mate hope it helps
www.motoxpartsonline.com
Oct 23, 2012 | Motorcycles
What size copper pipe is needed to connect my gas range to the gas supply
probably 15mm but this depends on output of appliance, distance from gas meter and wether other appliance are part of the pipe run.
Oct 17, 2011 | Kitchen Ranges
What does a F12 error indicate on a Noritz system
F12 occurs on a multi-system or quick connect. It means one of the units on the system suffered a flame loss. More specifically, it means the flame rod stopped detecting flame on the burner. The most typical causes are as follows:
1) insufficient BTUS (low gas pressure)
2) leaking heat exchanger
3) clog in the manifold, burner, or heat exchanger
4) stuck flue damper or improperly sized venting
5) dirty flame rod
6) damaged circuit board or gas valve
Sep 28, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
6 burner propane fed will not allow all burners to produce a usable flame for cooking,grill is not hot enough
I need more information, but I suspect you may not have a large enough regulator on your propane line. The only way to know for sure is to attach a gauge called a manometer onto the manifold that feeds the gas burners. There is a 1/8 inch pipe fitting on the manifold for this purpose. It should read 10 inches of water column. You need a capacity to run about 300,000 BTUs when everything is on at the same time. This requires a large capacity regulator. Also the line from the regulator to the range should be at least 3/4 inch pipe.
Sep 12, 2010 | Vulcan VG260 Gas Kitchen Range
I am purchasing a home with a kenmore elite gas range model # 790.3670--the seller doesn't seem to know if the oven is electric or gas. What is standard?
Electric or gas would be standard. If this is a stove like in the picture you provided, and is gas on top ... it is probably gas inside. You could always look to see if it has a burner or a calrod. See if there is a setting for Pilot or Igniter. Electric ovens don't need a pilot nor an igiter.
Of course, you could turn it on ... or pull it away from the wall to see what the connection is ... gas pipe or, if electric is involved, a very heavy electric cord - probably 50 amp 220 volts. If it has a small cord plugged into a standard wall outlet ... definitely gas fired. You say the top is gas so there will be a flex pipe for the gas ...
I searched Sears - they claim there is no such model.
Your agent should be able to tell by looking.
Mar 24, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Cooktop manifold gas line size
If this is brand new go back to the makers of the stove. And ask them why don't do any modification's to the stove it could invalidate any warranty.
Mar 19, 2017 | Kitchen Ranges
Gas line BSU"s
3/4 inch pipe is first choice but 1/2 inch pipe will work.
Aug 21, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Low gas Flame
check the vent plug on the regulator.
Dec 24, 2007 | Rangemaster 110 (Gas) Kitchen Range
Thermador Pro Harmony PRD304EHU (Dual Fuel) Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
1,125 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
