Question about Frigidaire FRT21H8 Top Freezer Refrigerator
  • Frigidaire Master
  • 2,651 Answers
Replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Posted on Oct 26, 2008
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
... locking when using key fob, only from the inside via the lock on the drivers door key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ... > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Why won't interior lights go off
Bad door switch. Replace it or just ignore it. Use LED light so it will not produce heat in the frig.
May 03, 2014 | LG Refrigerators
Fridgidaire light stays on
Check the door switch by pushing it in with the door open if the light goes off then the switch is ok if not change the switch.Then check where it comes into contact with the door and make sure that it is being pushed in.
Apr 13, 2014 | Frigidaire Gallery 25.8 Cu. Ft. French...
Frigidaire FFHS2612LS4 wont stop beeping
Hey Brandon, this is JK. Thank you for your post. I understand that your refrigerator is beeping none stop. When the door(s) have been opened for longer than 10 minutes, an audio alarm sounds and the interior lights shut off. This protects the liner from melting due to the heat produced by the light bulbs. The alarm will sound every two minutes until the doors are closed. Once the doors are closed, the alarm will reset. The refrigerator will also beep on some models to inform the user that the door has been left open and the cool air is escaping. Check to make certain that the gaskets on both doors have no gaps and that the appliance is maintaining the desired temperature. If all of these suggestions pan out and the problem still persist, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Hope this helps!
Mar 10, 2014 | Frigidaire FRS3R5EMB Side by Side...
Neff fridge door doesn't close all the way
Perhaps your refrigerator is not level.
Jul 14, 2017 | Neff Refrigerators
Refrigerater door won't close because lightswitch stays extended in on position. Door switch doesn't have food nor debris on it to prevent it from being pushed in when door tries to close.
I'd remove the light switch. IT should pop out of the side. You should unplug the refrigerator first, pry switch out. Tape up terminals. Push wires into hole where you can still reach them. Plug back in and be sure door closes. If all that works, buy a new switch and re-install
Jul 18, 2010 | Frigidaire Refrigerator Light Switch -...
Extreme rise in refrigerator temperature
You probably have a bad light switch or the door may be sagging. interior lights are definetly staying on with door closed.
Feb 16, 2010 | Refrigerators
Censor isn't working; temperature rising in frig (freezer ok)
Hi, do you think you could provide a model number. Some of those Samsung fridges have bad control boards at the back which could cause that problem OR the other possible fault could be the cabinet light sensor by the door hinge.( I'm going to assume it is this type based on the symptom you've described)Sooo...If you remove the hinge cover at the top you may find the receiving part of the sensor is misaligned or out of place completely which will prevent the semsor from detecting the door is closed, hence the interior light remains on and the temp rises and all sort's of unwanted side affect's. That is where I would start looking, but I don't even know if your unit has a push button door switch or the sensor style without a model number. However, based on several service calls for this exact problem in the past I'd say the chances are good it's the door close sensor if that applies to your model fridge. Hope that help's, let me know. Thanks for visiting fixya today. Good luck macmarkus :)
Dec 25, 2009 | Samsung Refrigerators
Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
Interior light does not turn off
Hi, try this  There s this knob that gets pushed when you close the door (the door puhses on it when it closes) and the light goes off
you can do it yourself, open the door and find the knob somewhere around the light or on top where the door closes and push it, the light should go off..
Pls rate my solution.. thank you
Apr 10, 2009 | LG LFX25960ST Stainless Steel French Door...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
290 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
