Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Yellow lines looks like an etch-a-sketch in top right and corner of screen
A series of yellow lines appeared in the upper right hand corner of the screen. The lines formed a weird pattern that looked somewhat like a yellow etch-a-sketch of vertical and horizontial lines. Then the lamp went out. We have ordered a new lamp but I can't see how the lamp could cause the line patterns. Any suggestions?
  • 84 Answers
Bad cap in vertical
Posted on Oct 22, 2008
How to factory reset a Konica Minolta bizhub c-654
turn off the machine. now press and hold the yellow button on the display and keep it pressed down whilst switching the machine on. When the display shows the columns you should see a black dot appear in the top right hand corner of the screen. now let go of the yellow button. now after 30 sec you should get the trouble reset screen. Select it and you will get a ok message underneath then reboot the machine
Apr 03, 2017 | Konica Minolta Office Equipment & Supplies
I have a KDF-55XS955 .A yellow splotch just appeared over night on the top right hand side. Starts about 1' top right corner, about 6" wide and the progress down the right side 3-4" from the edge...
This is a common problem for SONY LCD projection TVs. The problem is burned evaporated metal layer on the RGB color lenses. To fix it, you have to purchase a new light engine.
Sep 02, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
This is garbage
Send it for repair... It sounds like the Y-sus board and the upper and lower Y-drives... This unit uses the same panels as the Philips 42pf7320a so it shouldn't be that expensive for parts...
I wouldn't personally send it to Dell - instead look through the NESDA web site and locate a repair center near you and take the unit to them for an estimate.
Bill
Jun 11, 2008 | Dell W4201C 42 in. Plasma HDTV
Yellow line on right side of screen
Go to this website and read what it has to say, your TV's have major problems.
http://esupport.sony.com/sxrdsettlement
Apr 20, 2008 | Sony KDS-R50XBR1 50" HDTV
Bad light engine I think
I had the same sort of idea..bad color engine.Hitachi paid for upgraded replacement 'cause they had had so many similar problems with this model. My warrenty had expired so they did save me about $1200 but I was stuck with the labour cost approx $300...
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
169 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
