Question about Dell E173FP 17" LCD Flat Panel Monitor
Green lights on front but nothing on screen
Hello, Boy, am I glad I found this site before I spend boo-koo bucks on a new monitor. I walked away and my monitor went into screen-saver mode after 15 minutes as it's set to do. I came back again and the screen was blank, dark. I usually just have to move my mouse a bit to get my screen to show the site I was on. This time I moved my mouse and all I saw on the blank screen was a millionth of a second flick. Moved mouse again, same thing. Almost like the screen wants to turn off or on but doesn't. I've moved the screen to other desktops in the house and it's the same thing. I've double and triple checked all connections. All the green lights on the front seem to be just fine but I get no picture, only a black screen and a very slight/hardly noticeable flicker on the screen when I move my mouse. Turning off and on, rebooting, shutting down machine for a couple of hours and moving screen to other computers doesn't change anything. Have any ideas before I go plunk down money on a new screen? Thank you all ever so much for being here for us not-so-smart-when-it-comes-to-computers people. Amity
I have an E152FP and I was having the exact same problem...my fix was just to turn down the brightness below 60 and I have not had a problem since. Hope this helps...
Posted on Apr 29, 2007
    Problem Solver:
  • 15 Answers
I chased around the unit, disconnected the LCD for the controller and the back lights. I found that the green led stayed on with these disconnected.
Following this I discovered that the 1000uF 16V cap had swelled (been damaged). These are near the two diodes on a heat sync. I replaced both 1000uF 16V caps and the 470uF 16V.
And now it works, I even get the Dell Genesis logo when applying power to the unit.
Posted on Dec 06, 2008
How can I limit my son's time usage on his iPad?
now a day must children spend lot of time front of computers. And i have my little brothers like that. but the solutions witch my parents found is go out in the morning walk and found new friends in same age play with my brothers (bicycle swimm ) and after 8 hours front of their machine now they spend just 2 hours
Sep 14, 2016 | Tablets & eReaders
How to open a FLATRON L1718S LCD screen
Those screens are so inexpensive, it really isn't worth your time to try to repair them...Spend a buck and use your time for more important things!
Dec 14, 2012 | LG Flatron L1710S 17" LCD Monitor
Hi...Hannspree hu196 ,screen is blank but front light is on and goes green that it detects computer. Chris
this looks like the backlight has gone in your monitor, to test this connect this monitor to your pc and wait for green light. get a torch and shine it into the screen (really close up) you might see the log in screen.
To fix would probably cost more than the actual monitor is worth, would suggest going online and getting a cheap replacement, loads of them are listed on online auction sites.
D.
Oct 22, 2010 | Hannspree HANNS?G HU196D Monitor
Found problem but need to know capasitor
Check this page on our web site at: http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/ We have repair guides for all three versions of the Dell E173 monitors. If you need any additional information just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Pink Screen
Probably the color temperature setting or some other color settings - since you didn't specify your monitor's brand and model, it's hard to guess.
Anyway, most monitors have a "Reset to factory defaults" feature - you may want to make use of this...
Mar 10, 2010 | Dell Computers & Internet
My ViewSonic VX900 won't turn on. I have had it since late 2003 and it has operated flawlessly. Went to turn it on; nothing. No light, no standby light. Checked the power cord against another monitor and...
The VX900 has 2 different version of the unit. One version has an external power supply and the other has internal power supply. Since you said you changed the power cord I would guess you have the internal power supply version. The issue you have is caused by the capacitors on the power supply board have overheated and blown out. This is a common problem on many LCD monitors after a few years of use. If you open the back of your monitor and look at the supply board you should see the bulging capacitors. Check our web page at: www.ccl-la.com for Pictures and examples of what to look for and what you need to get to do the repair. If you have any questions let us know on our web site and we will be glad to help you get going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 12, 2010 | ViewSonic VX900 19" LCD Monitor
Hello. the problem i am having with my dell
Inverter has probably gone out. You can replace them for around 15 bucks. You'll have to remove the front plastic bezel from the lcd, and then right below the lcd you'll see the inverter. Just check to see if there are any part numbers on the inverter and search for it on eBay.
That's it!
Nov 20, 2009 | Dell E173FP 17" LCD Monitor
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Green shadows on picture
I understand that the problem does not go away with the replacement light engine. Avoid Hitachi and just spend more bucks and get a Sony or Panasonic.
Apr 12, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Dec 11, 2006 | ViewSonic VX910 19" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
518 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
