Question about Lands Phones
Cordless phone i need a back battery cover
    New Friend:
  • 27 Answers
The best or even the cheapier way is to seek for one fitting on second hand or the long way >>the original site of the product, regards
Posted on Oct 22, 2008
Turn ringer on
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means umts smartphone alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Dec 03, 2011 | Panasonic KX-TG2383 Corded Phone
My daughter dropped the cordless phone and there is no power to the phone , no display.please tell me how to troubleshoot
open the battery cover. remove the battery for about ten minutes. plug the battery back in and put the cover back on. then put it in the base (not the stand alone charging cradle) the light should flicker on the base for a second. take the phone out and it should be working.
Nov 03, 2010 | Uniden 5.8GHz Dual Cordless Phone
My alcatel one touch is stuck on emergency mode how do i get it off?
I took my batter and sim card out and put battery back in without sim. Next, turned on my phone and then back off; then removed cover and battery again. I then reinstalled the sim, battery, and cover. Turned it back on then it worked. I don't know if this will help in your case, but give it a try.
Feb 11, 2010 | Alcatel One Touch FIRST 20 Cordless Phone
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Changing the batteries on a cordless Logitech mouse
hello ,on the bottom of your mouse there is a cover that you remove thats were the 2 aa batteries go. the cover has the wireless info on it you'll see a spot were you can use your finger nail to pop the cover off then after installing your batteries just pop it back on.
Mar 28, 2009 | Logitech Cordless Mouse
Vtech 2656 cordless phone battery not charging
You need to replace the battery pack. Wal-Mart, Best Buy, Circuit City and a few other stores may carry this battery. Just call them first so you don't make a wasted trip.
Mar 26, 2009 | Vtech V2656 Cordless Phone (vtechvt-v2656)
Low battery in Uniden cordless phone.
Unless you have one of the water proof phones, hold the handset with the keypad facing your palm, and the top facing your body. Press very firmly at the endention on the battery cover pushing it in a little and down at the same time. Sometimes they are pretty tight but it should come off with a little effort. If it is a waterproof phone, there are four small screws at the corners of the battery cover that will need to come out before the cover will come off, be very carefull as the screw heads are fairly easy to strip and if that happens it is almost impossible to put it back together and still have it waterproof.
Mar 24, 2009 | Uniden Cordless Phone
Phone battery cover disorder
the wire goes down the middle of the pack and not the sides. tpo or bottom it doesnt matter
Jul 01, 2008 | Uniden TRU9480 Cordless Phone
"Low Battery"
Phone starts to beep after ten minutes or so then goes dead. Is there a way to change battery
Aug 25, 2006 | Uniden Cordless Phone exai398i
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
