Question about SanDisk Sansa m230 MP3 Player
On screen display not working
My MP3 player plays music but the on screen display has stopped working. I replaced the battery but it still did not come on.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
Sound plays but screen shows only distorted image
If the music plays but you cannot view screen then it sounds like the screen is faulty, it could be a loose connection or the screen needs replacing.
Sep 29, 2014 | Apple iPod nano
Sony Walkman NWZ-S618F MP3 Player - Screen display not working
I Have the same problem, but mine has vertical lines running on the display, try contacting sony support
May 12, 2009 | Sony Walkman Video NWZ-S618F MP3 Player
My MP3 player displays "License Expired" on the screen.
If you let your subscription to Rhapsody expire, you will get this message. If you didn't let your subscriptino expire then you will need to synch the files from Rhapsody itself back onto the player - the licenses have to be renewed once a year for some songs - once a month for others. If your subscriptino ever expires, you can no longer use the songs.
Feb 22, 2009 | SanDisk Sansa Clip MP3 Player
Blank screen
Typically this is an indication that your battery is dead. If the music is still playing but the screen is blank I would say a hardware failure and replacement would be the best option.
Jan 06, 2009 | SanDisk Sansa m240 MP3 Player
connect it to the pc using usb cable, then try itunes software to reformat your mp3
Sep 09, 2008 | iLO (2 GB) MP3 Player
Sansa MP3 Screen is white - display not working
1. Try resetting the player if it has a reset button
2. Drain the battery by leaving it on for an extended period until the screen in blank and no sound comes out of your ear buds. Then connect to AC adapter or computer and charge.
Feb 27, 2008 | SanDisk Sansa e260 MP3 Player
Starting displayed won't do anything
Look for a lock or hold switch on the player. Most players have one of these to stop you accidentally switching it on or off when you're not using it.
Let me know how you get on!
Jan 17, 2008 | Delstar DS 31024 MP3 Player
Won't play any songs.
I had this problem with my player (th 1101) when I was transferring songs from iMesh. After awhile I found out that even though I could listen to the files on the computer some wouldn't go on the mp3 player. Looked it up and there is an encoding on some tracks (preimium tracks they call it) that unless you pay for them they won't transfer off the computer (CD, MP3 players ect.). They also had free tracks that works just fine. Hope that helps
Nov 02, 2007 | RCA TH1101 MP3 Player
Display prob
Is the screen cracked?
Does it appear to be leaking a liquid?
If so, there is no "fix" for it, you will need to have the screen replaced.
Best of Luck.
Oct 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer does not show MP3 player as connected and how to stop a song playing
If you installed the firmware update, you might have forgotten to change the device to MSC mode.. try going to settings>USB mode>MSC This should probably work.. to stop a song while its playing, click the |<< button while you have the screen with the current song. (you can pause a song on this same screen with the >|| button) If you have gone back to any of the menu screens, wait for a couple seconds and the player will automatically go back tot he song display screen so you can stop the song.
Dec 26, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
