Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
DVD says no disc
When I put in a dvd in, the screen will say incorrect disc, or no disc. I can put in a cleaning disc in and the sound is perfect for the instruction?? It seems that when my sat. box is on it says incorrect disc, and when I turn that off it says no disc.
  • 563 Answers
SOURCE: when i put a dvd in it says
If the player displays this message for every disk you've tried to play (presuming you've tried several) there is likely something wrong with the DVD mechanism and it needs to be repaired or replaced. Some would telll you to purchase DVD lens cleaner and try that, however, in my experience this is usually a waste of money. I have yet to see a DVD with a lens so dirty that it wouldn't play any disk until it was cleaned and then it played everything. If you're under warraty the repair/replacement will likely only cost you shipping of the player to an address you'd get from the manufacturer or your manual. If this is attached to your TV, you'll get in-home service if the screen is big enough. Oherwise you'll have to carry the unit in or ship it someplace for exchange/repair.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 11, 2009
0 characters
1 Points
What does "incorrect disc" mean
It could be one of several things:
  • Dirty disc. Clean with outward strokes with a paper towel and water or Windex if needed
  • Dead DVD player
  • DVD may be for a region that your player does not support.
  • If the DVD is burned (home made), sometimes players are not forgiving and not all will play burned discs.
Feb 11, 2012 | Disney Princess TV/DVD Combo
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
My DVD player keeps saying "incorrect disc" when I
cd cleaner may help. lazers find it tough to read discs with dust on it.
Dec 30, 2010 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Toshiba TV/VCR/DVD combo (MW20F51) won't read/play dvds.
this a laser unit dirty or dead, needs to be cleaned with a laser cleaner kit or replace the laser unit
Feb 19, 2010 | Combination Televisions
When i put a dvd in the dvd player it just comes on screen saying theres no disc
Try cleaning the lens with a CD/DVD cleaning kit that you can buy at a local eletronics store. If you have tech skills, open the player up and clean the glass eye reader lens with some rubbing alcohol using a Q-tip. Make sure the DVD you are using is not too scratched up. If it still don't work after you cleaned it and tried different disc then replace the optical reader drive
Nov 04, 2009 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Incorrect disc message
Sounds as if the carriage has been trashed somehow. Incorrect loading of a disc of any sort can cause this sort of message...accordianman
Mar 16, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
Dvd stuck on the reading part
Sometimes the problem is CD DISC, Next Is the laser lens, cleaned the lens with 100% cotton buds.. or if not working after you cleaned the lens, replace the laser eye A new one!
Sep 14, 2007 | Toshiba MD13P3 13 in. TV/DVD Combo
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
78 people viewed this question
Top Toshiba Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Toshiba Combination Television Expert? Answer questions, earn points and help others
