Question about Dell Inspiron 1501 Notebook
Dell Inspiron 1525 stays black
When I log in my password, the screen stays black. The cursor is still showing. I am hit f8 at when I turn on computer to click the problem but no luck. Help!!
  • flipflopper7 Oct 22, 2008
    I am still having the same problem, the express test reported no problems. Now I am working on the Vista program for memory problems.So far, I am having the same results. Is Vista still this bad? Mojave lied....
  • Anonymous Mar 15, 2014
    When I turn on computer there is only a black screen and a cursor
  • Dell Master
  • 998 Answers
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the “Run the 32 Bit Dell Diagnostics”. Next select the “Express Test” and see if any errors are detected. If no errors are reported, then your operating system software is probably the culprit.
Hopes this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 22, 2008
  • Walter H Boehm Oct 22, 2008
    Actually Vista has improved by leaps and bounds since it was first released. Even XP had it’s problems when it was first released, ( XP has a service pack 3 out now). If your laptop is under warranty, try calling Dell.
    One last thing you might try is to perform an automatic Vista repair by booting from your Vista re-installation DVD.
    1) Put the Windows Vista installation disc in the disc drive, and then start the computer
    2) Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
    3) Click Repair your computer.
    4) Click the operating system that you want to repair, and then click Next.
    5) In the System Recovery Options dialog box, click Startup Repair.
    6) Restart the computer.
    Hope this helps.
    Thank You.
Dell Inspriron 1545- black screen no home screen
can you get in windows safe mode by pressing F8, and get screen? it might be a display driver
Jun 10, 2012 | Dell Inspiron 1525 Laptop
Dell 1525 laptop-lost password and cannot get to the repair your computer icon
type in 6gzrt9a8 it should boot up and hopefully there isn't a windows password. the above number is a bootup password only.
May 26, 2012 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
When I go to log into my computer, it first brings up a start windows... screen and askes me how I want to start it. I have tried it in every modw, and to start it normally. I have also pressed F8 until it...
It sounds like your hard drive is bad or at least has bad sectors where important Windows files are stored.
Unfortunately, Windows Vista does not have a "restore" function - as you've seen.
You could do a fresh install of Vista, but unless it's done in a very specific way, you will lose all your personal files like documents, music, pictures, etc.
There are various disk scanning and repair software programs, but most of these require that you be somewhat computer tech-savvy since they can cause permanent data loss if not used properly.
Mar 26, 2017 | Dell Inspiron 1525 Laptop Midnight Blue
Dell Inspiron 1525 start up problem
This may be the result of a bad patch from Microsoft or other program. If you are using system recovery then you can try to restore back to before this occurred.
Please hit F8 when the computer is starting up to go into safe mode then use system restore. The other solution would be to go to safe mode then alter your start up programs . This is a bit more confusing but you can go to start run then type msconfig. You must be VERY careful when modifying this as it can cause more issues.
Hope this helps
Mar 15, 2010 | Dell Inspiron 1501 Notebook
The windows start up shows and then it shows the scan bar and then a black screen and nothing else. How do I fix this?
Reboot the computer and keep hitting F8 to enter the recovery screen. Boot into Safe mode, and run system restore (programs-->Accessories-->system tools). Restore your computer to a previous date when it worked properly.
Jan 10, 2010 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
My dell inspiron 1525 boots up like normal but when it comes up with where i normally log in, the screen just goes black, but you can still move the cursor, any ideas of what i can do please?
The file which is known as "winloader" is gone bad. You should try to boot your computer with last known good configuration.
To do that, just restart your computer and keep tapping F8. Once you reach the advanced boot option menu you will be able to see the last known good configuration option.
Press enter on that option and your computer will be set to the last configuration on which your system was running fine.
With regards,
Ankit
Oct 17, 2009 | Dell Inspiron 1525 Notebook
Black Screen
try booting from a cd like the reinstall cd for windows that came with the computer. when starting hit F12 to show 1 time boot menu; select cd drive; hit any key when asked to boot from cd. This will tell you if its a software or hard drive problem.
Feb 18, 2009 | Dell Inspiron 1525 Notebook
In window vista show black screen with cursor
I have a dell inspiron 1525 ..the screen blacks out leaving the cursor only... hod do I remedy?
Nov 29, 2008 | Computers & Internet
Dell Inspiron 1501 Notebook Logo
117 people viewed this question
Alun Cox
