Question about LG Washing Machines
Need to replace water pump - LG Washing Machines
  • 62 Answers
This is easier then most people think. You unscrew pump from trap door in front of machine. Then you tilt it back, be very carefull. There is a hole on bottom of machine, stick your head in there and locate plactic clip on bottom of water pump, push up and slide pump off, You will need to remove the hoses first.
Posted on Oct 22, 2008
How much does a water pump replaced cost for a 2003 Jeep Liberty?
Water Pump Replacement Cost for Jeep Grand Cherokee ...
repairpal.com > Estimator > Jeep > Grand Cherokee
This is a national average for all Jeep Grand Cherokee model years, but you can make it more accurate by adding your car info and ZIP. ... When replacing the Jeep Grand Cherokee's water pump, the drive belts and/or timing belt may need to be removed. ...Jeep Grand Cherokee water pumps ...
Water Pump Replacement Service & Cost - YourMechanic
www.yourmechanic.com > Auto Repair and Maintenance Services
How much does Water Pump Replacement cost? Get an estimate instantly. Service, parts, cost & recommendations from YourMechanic. Your definitive guide to ...
Replacing a Water Pump Cost - CostHelper.com
Dec 01, 2015 | 2003 Jeep Liberty
Is it safe to drive your car if your water pump needs to be replaced
No its not.The engine will get hot,then overheated and at last damaged.
So its advisable to replace water pump.
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
Feb 15, 2012 | 2004 Dodge Stratus
I need a chart for the water pump
Feb 01, 2012 | 1996 Dodge Neon
Trailblazer won't start after water pump relacement
Many a times the problem occurs due to timing not adjusted,in many cases the timing belt also needs to be replaced while water pump replacing.
Or its also possible that water pump not replaced properly or timing got mistimed.
I suggest you to check few help links.-----------
Below is the master help link provided to go through belt routing diagram:---Timing belt, drive belt, serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks
Jan 26, 2012 | 2004 Chevrolet Blazer
I need to replace the water pump and put the car back to geather
Jan 21, 2012 | 1996 Mitsubishi Galant
Water pump leaking from sseap hole
replace water pump,bearing is bad
Jan 06, 2011 | 2003 Pontiac Montana
Water pump pulley
The water pump needs replaced.
May 08, 2010 | 2006 Pontiac Grand Prix
Pulley on water pump shaft has sloop
If you have shaft play on your water pump then you need to replace the water pump.
Dec 03, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Why is there a water leak coming from the water pump?
i would say you answered your own question, if there is water leaking from the water pump i would say the water pump is leaking and it needs to be replced,either the bearing is bad and its leaking out the shaft,or the seal is bad and its leaking outta there either way you need a new water pump,check the belt for wear when you replace it,,
Oct 07, 2009 | 1998 Dodge Caravan
Do I need any special tools? How Hard is it?water pump 2002 aztek
take everything around your water pump of and use a metric 10 box end wrench
Apr 30, 2009 | 2002 Pontiac Aztek
Washing Machines Logo
54 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
