FixYa.com
Tags:
Tappan TGF657 Gas Kitchen Range
Oven will not heat up (by 2 users)
posted by crog on Jul 27, 2006
When I set the temp and oven to bake it doesnt seem to ignite.
After awhile you smell gas.
Is there an ignitor that can be replaced?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 09, 2008
I have a GE gas wall oven. The oven will not light. The gas is on, but I do not smell any gas even after several minutes.
Best Solution
posted on Jul 28, 2006
Helpful (85)
catriver
Rank:Guru Guru
Rating: 94%, 2467 votes
The oven ignitor is more than likley your problem. It has to draw a certain amount of amps to open the gas valve all the way. If it is weak it may not be doing it's job. The part number I have for this ignitor is 316030600. It's located under the flame spreader in the oven. One other thing to check is the burner itself. This would be the tube that the flames come out of. Make sure that is is not rotted or plugged. Catriver
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
Clock and temperature lights...
I have a Tappan TGF657 36"... Answer This...
dim led display
led display dim barely... Answer This...
F1 Reading on Panel
I have a Tappan Model... Answer This...
oven not hot enough to cook at...
I hit up arrow on display to go... Answer This...
Tappan Electronic Ignition Oven
When the oven is on, the range... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
