Question about Vehicle Parts & Accessories
Python 488v/p/x Hello - I just purchased a truck that has a python alarm. But my remote doesn't do anything and there is no security light on in the truck. Where would I be able to get a hold of a manual.
  • steve202 Feb 01, 2009
    Yes we also just purchased a used 2003 with one of these remotes and no instructions. I went to the Python web site and did not find a pdf with the 488 model number. The battery had been removed and any time we insert the battery the transmitter starts playing little tunes but no action from the buttons , so we removed the battery. So far I have not found a site with info on this transmitter, evidently out dated. Any help would be appreciated.
    Thanks in advance.
  • Keith Methot
    Keith Methot May 11, 2010
    you sure of that model # ??
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 33 Answers
SOURCE: I want to diable the alarm without,not the door
Locate the valet override/program button. Turn key to "run" position, push and hold button for a couple seconds, and that should put it in valet mode. Door locks will still function with remote, but alarm will not arm. LED should stay on solid.
Posted on May 06, 2009
albaby6
  • 58 Answers
SOURCE: need to pair the remote with the alarm
If you know where your Valet switch is, turn the ignition on, push and release the valet switch once, then push and hold it, you should hear the siren chirp once, then while still holding the valet switch, push the #1 button on the remote, you should hear the siren chirp again. it is now programed. If you have the package that came with the remote, it should have a table on the back that tells you how many pushes of the valet for which feature you want to program. Most remotes are one push for all features, some are 7 or 8 pushes. So if it say auto learn is 7, turn the key on, push it 7 times, the push it again and hold it, the push #1 button, and it's programed. Hope this helps. If all else fails, take it to your nearest best buy, if they charge you to program it, it won't be much.
Posted on Aug 21, 2009
tripletauto
  • 1450 Answers
SOURCE: hi , i lost the remote for the alarm to my truck
is this an aftermarket alarm? you can look on ebay see if you might get lucky and find the remote. other than that all you can really do is remove alarm or upgrade it to a newer unit
Posted on Nov 12, 2010
  • 902 Answers
SOURCE: I wanted to install the Python 1401 remote start
yes it can :) all remote starts actually run off different relays then alarm systems (factory or afgtermarket)
Posted on Mar 27, 2011
afarri
  • 1386 Answers
SOURCE: I have a Python 991 remote start & security system
Hello and welcome to FixYa!
Have you tried having the security module replaced? This is common cause of a faulty module (the black box where the circuit board is located). I suggest that you have it replaced to resolve the issue. You can just do it yourself for they are plug and play.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jul 23, 2011
Is 448V remote compatible with Python Car Alarm?
if its lit solid that usually means a problem with the system... so the alarm portion is most likely not active... or it might simply be in valet mode... without knowing the model of your car that's the best I can offer...
May 05, 2016 | Python Vehicle Parts & Accessories
Door locks unlocks
may be the remote was opened ad the pads inter changed
Mar 21, 2014 | Viper Vehicle Parts & Accessories
Python alarm (460 HP) will not lock doors
The lock button in your remote may be faulty.
Nov 13, 2013 | 460HP Security System
A few times each week when i use the remote start function on my Python 991, the truck will start for a second or two then the horn starts blowing, lights flash then the truck shuts off and I lose all...
It sounds like the factory alarm is setting up. To make sure the factory alarm does not come on you should make sure all doors are closed before you actually hit the remote to lock the doors. Do not lock the doors with the switch on the door. Make sure you use the Python remote only and all doors closed before you press the lock button.
Jan 23, 2011 | 5702P Python 991 ResponderLE 2Way Security...
I lost my key with the python remote on it and when i use my spare key i cannot turn the alarm off what do i do.
The python alarm has a manual alarm disable. Upon entering the vehicle, turn ignition on, press and release valet switch. You should hear two chirps confirming that the alarm is disabled. Start the vehicle.
Oct 09, 2010 | Python Vehicle Parts & Accessories
Python car security won't let me start my car
It sounds like you might have a dead battery in the car. When the alarm is losing power due to a bad connection or faulty battery it will act exactly as you have described. You can disarm any DEI alarm by turning the ignition on with the key and pressing the valet switch one time.
Hope this helps you out.
Jan 11, 2010 | 460HP Security System
I want to diable the alarm without,not the door locks It is a (Python 426P 460HP security system)It does have a remote.Thanks
Apr 22, 2009 | 426P 460HP Security System - 426P
Vehicle Parts & Accessories Logo
963 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
