Question about Maytag Washing Machines
I have a Maytag LAT9806AAE dependable care washing machine and it started leaking from the center of the drum, I have taken the adjatator, nut, mounting washer, and inner drum off/out. The inner drum sets on the stem seal and hub assembly. I took the set screw out of the hub assembly, how do you remove the hub assembly?
3 Suggested Answers
  • 1028 Answers
SOURCE: TRYING TO REPLACE THE STEM
that's and old one ..try turning the assembly counterclockwise ..if i remember right it screws off you may need a spanner wrench to get it to start
Posted on Jul 20, 2008
MNTECH
  • 1543 Answers
SOURCE: GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Posted on Jun 12, 2009
Grinding noise and will not adjatate
Sounds like the drum bearings have gone try turning the drum by hand if it still grinds then you will need a bearing kit tricky to dismantle and fix but no impossible .
Nov 09, 2014 | Maytag Washing Machines
Maytag washing machine LAT9806AAE drive belt burnning
Hello, Thank You for using FixYa. I will be helping you today.Lean the unit back and see if you can turn the center pulley both ways and if pump pulley turns free if so just replace the belt they do start to slip over time its part 12112425. If one of the two pulleys dont turn it can be a trans or drain pump issue.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Maytag Washing Machines
Maytag hav2557 vibrates excessively
sounds like the drum is loose. remove softener dispenser, usually a plastic hand nut, then you should see the drum nut, may be under softener goop though. check if tight. other thing could be one of the drum stabilizers broke, usually drum has 4 of them attaching drum to dryer frame. place unit on side and check
Aug 12, 2009 | Maytag HAV2557 Top Load Washer
Maytag LAT9806AAE- Top Load Waher- Loud Banging During Spin Cy
Damper pads, P/N 203956, $23 at searspartsdirect.com might do the job. Can't put them in yourself though, unless you are the Maytag man. Look for felt pads at the bottom of the cabinet or black dust around the damper at the bottom.
Other, more expensive problems might be a warped drum or a bad transmission. Are the springs o.k.?
Jan 18, 2009 | Washing Machines
How do you remove the agitator if something is caught underneath.
On a Maytag the agitator either has a bolt under the center cap, or a set screw along the side about 3/4 of the way down. Maytag Alantis and Performa models have a removable agitator cap with a bolt underneath, while the Dependable Care series have a set screw. In either case, you loosen the nut or screw, and the entire assembly will lift straight up. Sometimes they stick and require a little effort to remove. I hope this helps you.
Sep 04, 2008 | Maytag Washing Machines
Maytag Mav2755AWW
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Maytag MAV2755A Top Load Washer
Washing Machines Logo
247 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
