Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Overloaded storage drawer
Ok so we needed more space and started stacking baking stuff in the drawer under the oven. something got stacked wrong and now i can only open the drawer about an inch. anyone have any suggestions?
  • barncat11 Oct 17, 2008
    Storage drawer stuck on right side but a knife blade slid into the opening shows nothing jamming it from opening.
  • Anonymous Mar 14, 2014
    I have a cookie sheet slotted into the lower oven casing that is now holding the drawer closed. I have 2" to work with and the screws on the front of drawer spin at bottom if you were going to suggest removing the front panel for access... Any ideas?
I went from side to side first then all the way back to almost laying oven on its back and then slammed it forward when it hit the ground i had my wife pull on the draw and that was the only way we got it open
Posted on Nov 05, 2012
    President:
  • 878 Answers
There is no easy way to handle this deal. You cannot get to the bottom drawer from the oven. What I did when I had a call on this situation once was to pull the range away from the wall and tip it back. This way I was able to dislodge the pan that was preventing the drawer from opening...good luck on this...Catriver
Posted on Jul 28, 2006
Gas fireplace log placement
google make model of fire this should give you makers web site and you can down load a manual with the log positions.
Apr 08, 2017 | Heating & Cooling
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
Microsoft Visual Basic Run-time error ' 28' Out of stack space How to fix it?
Hello and Welcome to FixYa!
Out of stack space means something is continuously loading the data onto the stack and when the stack gets full the it has no more space and throws the exception.
Run-time error '28' is the error code for Stack overflow.
There may be many reasons behind this, it depends on your coding.
You should see this article my Microsoft to get hands on the issue.
I hope you will have a clearer picture after reading that, If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh: FixYa Team.
Jul 13, 2011 | Microsoft Visual Basic
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
Stack overload at line 48
You hav run out of stack space. This means you have gone into too many levels of subroutines for example and have insufficient storage allocated for the return vectors and variables.
You will have to increase memory available for the stack, or have less levels of subroutines.
You may also hava a re-entrant subroutine that keeps calling itself until the return stack overflows.
Jan 02, 2010 | Computers & Internet
Dishwasher beeps constantly and gives fault code that the flood switch has been activated. Neither drawer will trun off. It seems the fan keeps going, and is very noisy. It worked fine last night.
Hello there:
here is some ideas that will help you clean off the flood switch thatis causing the error
first unplug the power going to the machine
If you by accident overloaded the top drawer and this will allow water to get into the base an trigger the flood switch. which causes the error that you get .
Take the bottom drawer cover off first then took the whole drawer out and gently manuevere it to where u can get into the bottom of the unit.
use a towel and dry up any visible water.
use few paper towels to get into and under tight spaces.
now Take a blow dryer and blow the in the base for about 10 minutes. once there is No visible signs of water any where
put it back together and it should work . ok
Hope this is very helpful for you
Best regards MIchael
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Can I stack them easily? Do I need any accessories?
yes you need the stack kit. you can buy it a sears or any local appliance parts store. youll need to have to model number of the washer with you so youll get the right one
Nov 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
488 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
