Question about Sony KP-65XBR10W 65" Rear Projection Television
Sony KP-65XBR10W After awhile, shuts off
When it is running it has blue lines running across it. After the set has been on for about 1/2 hour, it will flash and then shut off or go into stand by. We are trying to decide if it
is worth fixing. We are having trouble finding someone to come to the house to
fix it. And it is to heavy to haul into a shop. Can someone give me an idea of what it should cost to fix or is it worth it?
  • 320 Answers
It sounds as though you have an bad blue CRT. Due to the age of the unit and the likely case that you also have weak green and red CRT's, based on the age, it would probably not be a good investment. Please be sure to rate my response if you found it helpful.
Posted on Oct 22, 2008
Sony KP-65XBR
This is the sony support page. Try this out. Click here
Jan 12, 2008 | Sony KP-65XBR10W 65" Rear Projection...
I have a Sony KP-65XBR10W 65-inch HDTV - green flashes shut down
Most likely you have a Green CRT that is failing. Sony no longer stocks the CRT assemblies for most of the older Projection sets. Instead what is required is to send the Green CRT assembly back to Sony (minus the Delta Lens), so they can replace the Tube on the Optical Coupler. This is a major cost of about 400.00 to 500.00 for the CRT plus the the tear down and reassembly time. Then you need to do a major Convergence alignment because the other two CRTs are aligned to the Green CRT. Due to the cost and the fact that Sony will not be supporting the older sets much longer, I would not invest the money into it.
I hope this helps,
Skyassoc
Feb 09, 2010 | Televison & Video
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
KP-65XBR10W Flash of Red!!
It sounds as though both of you have intermittent shorts in the picture tubes which I have seen before. Unfortunately, due to the age of the units and the likely scenario that you will be looking at relacing the other CRT's, it is probably not a good investment to repair the sets. If you are still interested in repairs, there are places that will rebuild the CRT's, but I believe the original parts are no longer available. If you found this solution to your liking, please be sure to rate me. Thanks.
Aug 12, 2008 | Sony KP-65XBR10W 65" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Blue lines across screen sony tv
blown fues on the G board, that should fix my problem
and or might need to replace stk392 convergance amp ic's
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Sony KP-46WT500 46" Rear Projection...
Blue screen of death on a tv??
this could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
Sep 19, 2007 | Sony KP-53V45 53" Rear Projection...
Sony KP-65XBR10W 65" Rear Projection Television Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
