Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Blurry spot A while ago I got a yellowish spot on the right side of the screen. The same area eventually started to become blurry. The spot has now grown to almost a quarter of the screen. What would cause this?
    President:
  • 3,130 Answers
Depending on the age,as you did not mention, you could have a contamination inside the surface of the Picture tube in the liquid coolent or silicon spacer in between the crt and the lens assy. This will get worse with time and will happen most likly again on the other tubes unless you have a pro come out and replace the liquid and refill with fresh stuff. Its not a job for the unexpirenced person with TV sets. You may want to think about another set depending on the age of this set and the Estimate you get on this set. Good Luck
Posted on Jul 27, 2006
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
Dark Spot on Lower left screen
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD150-200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 03, 2014 | Acer H5360 3D DLP Projector
It's a small black spot near the bottom left. It
it sounds like a small pieces of dirt got inside the photo mechanism and may need to be clean proffesionally
Jul 21, 2010 | Canon PowerShot SD1100 IS Digital Camera
LG LCD picture blurry/polarized
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 18, 2017 | LG 42LC2D 42 in. LCD HDTV
Blurry screen on 50in Hitachi LCD
Sounds like you need a bulb replacement, if you watch tv a lot ave life is about 5 years
Sep 14, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Blurry spot on bottom left of picture
It sound like you have some dust particles or a smudge spot on the CCD screen (actually on the low-pass filter in front of image chip). To leave an image on CCD, the dusts must be closer to the image plane to be registered so it should be somewhere closer to the screen or right on it. Take a look at the screen with "CCD Clean" mode and blow out any dust. If the smudge is on the screen, I recomend trained tech should clean it. good luck. For further assistance by email, go to www.camerarepairjapan.com
Mar 26, 2009 | Nikon D40x Digital Camera
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Jan 05, 2008 | HP VP6121 Multimedia Projector
I have a Casio EX 260, not the EX-S600
Ritz LIED. What u can try doing is resetting the camera.
Press menu
go to setup tab
go up one to reset
press right arrow, highlight reset
press set button in middle of arrows.
Also make sure you are only pressing shutter button half way down and allow time to focus before pressing rest of way down. Can also try changing focus mode from spot to multi. I believe that is under the rec tab in the menu. I think it is called AF AREA. Can't remember for sure.
Try that. If it doesn't work then you will have to send it into casio.
Nov 08, 2007 | Casio Exilim EX-S600 Digital Camera
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Blurred monitor image to black only..
There is an issue with the screen as you say that the sound is coming from the system.I would suggest to contact the manufacturer and get the screen replaced.
Sep 20, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
