Question about Maytag MER6769 Gemini Electric Kitchen Range
Maytag dispaly show OFF whenever i touch (no dispaly at all) after a power failure.How to reset?
  • cezarzzz Nov 05, 2008
    Nobody gave me an answear to my quest., so? where can i find the answer?
  • tweetypie414 Dec 19, 2008
    Don't know how to reset the range after a power failure.
Maytag display show OFF whenever i touch (no display at all) How do reset?
Posted on Nov 02, 2008
Maytag electric range control panel frozen. Time shows on display. Only buttons 1-6 and 0 will beep, none other will function at all. Is there a "hard reset" combo? Help?.
You may have a bad touch pad. there is no reset other than shutting the power off and resetting the breaker or unplugging the stove and plugging it back in.
Oct 09, 2014 | Maytag Kitchen Ranges
My laptop dispaly goes dim after 5 min on plug in mode but does not become bright when i touch the pad
If you right click on the battery icon in the tool tray, select power options and reset the brightness as you would like it.
Feb 16, 2011 | HP Pavilion dv6000z Notebook
I have a whirlpool sf325lekq0 and it shows a code of PF on the dispaly and beeps. What does the PF indicate?
That would indicate a power failure you can press the clear off nutton and it should get rid of this PF displayed
Aug 31, 2010 | Whirlpool SF325 Gas Kitchen Range
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Kenmore top-load washer,"Elite" touch-pad control shows "PF" , how do I reset to get a cycle start?
PF is power failure. Your home has experienced a power failure since the last use.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 16, 2009 | Washing Machines
Power Failure
Try unplugging the unit for 5 minutes and let the control panel reset.
Nov 20, 2008 | Maytag Dryers
F1 SHOWS UP IN THE WINDOW AND BEEPS LOUDLY
Looks like F1 for Maytag is possible touch pad assm. Try disconnecting power for about 20 -30 mins see if it resets itself.
Jul 10, 2008 | Maytag Kitchen Ranges
Maytag MER6769 Gemini Electric Kitchen Range Logo
252 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
