Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker ice doesn't freeze all the way .what can i do to make the ice cube freeze
    Champion:
  • 210 Answers
Feel the bottom of icemaker (i/m) if hot, replace i/m.
Posted on Nov 05, 2008
Why would my ice maker start freezing all my ice cubes together?
ice maker made cubes, but you shouldn't put in freezer any warm staff, its melt ice for while after freezing them together
Jul 29, 2014 | Jenn-Air Jenn Air Refrigerator Replacement...
My Emerson ice maker, will make the 1st round of 9 ice cubes, then it fills back up with water and makes a clicking noise and won't freeze anymore cubes I'm so sad, I don't have money to buy a...
If it won't freeze the cubes that because the freezer section is not cold enough to freeze them. the ice maker itself dose not have any cooling in it. it all comes from the freezer. sounds to me like there may be a problem with the ice maker and it may need to be replaced.
Aug 05, 2013 | Refrigerators
Frigidaire refrigerator glhs38egsb0 ice maker freezing up
Hi - Is the wire signal arm in a stuck position or has any ice cubes stuck? If so, try turning it off and remove any ice cubes stuck to the wire signal arm or body of the ice maker and wait approximately 8 hrs. Should these suggestions prove to be ineffective and ice maker continues to freezer up, I recommend contacting a professional to properly diagnose and repair the unit.
Sep 29, 2012 | Refrigerators
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
My scotman model sce170a1a.goes into harvest to
That has to be a faulty control wouldn't you think?
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Feb 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
