Question about Whirlpool GU2400XTP Built-in Dishwasher
GU2500XTPS3 QUIET PARTNER - NO START.
I have a fresh problem - the dishwasher will not start. The following things have occurred;
1. The pots and pans cycle light is flashing.
2. The time remaining is reading - -.
Can anyone please assist if they have seen this problem before?
Take care.
Javajoe
  • martha-johns May 10, 2009
    dishwasher model gu2500xtpb1 has express clean light flashing not running. sears tech called out said electronic timer faulty . have replaced timer board, now nomal wash light flashing still not working
GU2500XTPS3 QUIET PARTNER - NO START. - 23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Posted on Jul 21, 2010
Whirlpool quiet partner iv. Turn breaker off then on. Displays 4H then goes off few mins later. Press the cancel button and then the POTS AND PANS along with NORMAL buttons start flashing back and forth.
this is not from me but i found it and am passing on..
Hi
Thanks for using FixYa. Error code 4h means 4 hour delay start which means that the dishwasher is in delay start mode and has been set to 4 hours. You can either wait for 4 hrs or to start it immediately press the cancel button to cancel the delay start option. After this program the cycle and options and press Start again as the dishwasher will not start the wash until it reaches the delayed hour i.e. till 4hrs. If after 4 hrs still the light blinks and it wont start then you'll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Dec 28, 2017 | Whirlpool Dishwashers
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
WHIRLPOOL QUIET PARTNER IV
Ok this can mean 2 things.
Pump or filter is clogged
or heater is not working correctly. Can you give the precise model number?
Aug 09, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
578 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
