Question about GE Advantium SCA2000B Microwave Oven
Maytag Microwave MMV5000ADA door handle PN 56001137
Our microwave works great. Outer handle broke at the bottom fastener (female boss split in half). Manufacturer has no idea if part will ever be available again. Can't find it anywhere locally or online. I'm at the point of trying gorilla glue. Any recommendations? I would rather not throw out the appliance for a handle! Thank you! Ron O. Orlando FL
  • 126 Answers
If you go to sears.com and click on appliances then click on parts type in the model nunber you will bring up a parts look up for that microwave. Then you can order the handle. make sure you get the right color code.
Posted on Jan 01, 2009
  • GE Master
  • 9,086 Answers
I checked a few sources and it is shown to be in stock at the Sears parts site here:
Handle, door (outer-alm) (series 10) Part # 56001137
Category: Large Kitchen Appliances
$29.57 In stock
Posted on Oct 22, 2008
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
My push button to open door broke. how do I get the door to open?
Disconnect microwave from power socket, remove cabinet outer cover,and lift the top or bottom door latch at micro-switch bracket with a screwdriver, the door can then be opened.
Oct 24, 2015 | Maytag Appliances Over-the-Range Microwave...
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
I have a Kenmore model #721.89940490 The door handle broke off and need to replace it, I do not see any screws. how do I access the mounting screws.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. , but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door. In order to access them you have to remove the inner door frame. You can find how to remove it in the video clip from one of our previous posts.
Aug 03, 2009 | Kenmore 62702 Microwave Oven
Kithchenaid Microwave
You'll notice there are small clips holding the stainless outer door to the black metal inner door. Get a bunch of putty knives (butter knives work too) and work a knife into about every other clip. I did it on the bottom. Once you're sure all the bottom clips are free, and you've removed the three screws on the side of the door, you'll be able to gently pull the stainless outer door away from the black inner door and get to the handle screws.
I bent both doors in this process, and tore the black plastic liner into a few pieces while I was getting everything out, so I had to buy a new door ($200). Be careful.
Sep 09, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
GE JVM1650BB005
You can search under Repair Parts and enter your full model number JVM1650BB005 and get an exploded view diagram here: http://www.geappliances.com/shop/prts/ That diagram can be a great help. Also, I've attached below a door panel diagram from a Sharp model. Your GE disassembly may work the same way. If you haven't already taken the door off the microwave, I would recommend you don't unless you leave the hinge assembly attached to the door and remove the door from the hinges. It's critical to be sure you get (or keep) the door and hinged aligned exactly as they were to prevent leakage.
Dec 05, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE Advantium SCA2000B Microwave Oven Logo
231 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
