Cannon printer MultiPass.MP390 waste ink near full the waste ink tank(which holds the ink, used for print head cleaning) is nearly full. What do I do The printer tells me this when I am using it. It says contact the canon customer care center.
  • 1 more comment
  • Anonymous Nov 10, 2008
    When printing orange light flashes and message "used in tank nearly full - press ok to continue". How long can you do this - and what to do when used ink tank IS full.
  • Anonymous Nov 18, 2008
    our waste is now full and the printer is no longer working
  • Anonymous Mar 27, 2014
    cannon i 455 printer
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Posted on Dec 01, 2008
Waste ink near full
There is a collection area in the printer that when the print head are not in use they rest over. It usually has a sponge\foam material. It collects excess ink and keeps the print heads clean. Any way, waste ink near full means it needs to be changed.
Oct 29, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
What does "waste ink near full" mean?
There is a "Trough" sort of, Under the park/rest area where the print head stays when not in use, or Parked. This holds a any excess ink that comes out of the cartridge. This needs to be removed and cleaned. according to the manual. This message is now stating the obvious. :)
Jan 27, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canon Multipass390 Waste Ink Tank near full
Have a look here
http://resetters.blogspot.com/2009/04/reset-waste-ink-tank-canon-mp390-and.html
Apr 29, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Printer screen says waste ink near full
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Mar 31, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Message code on cannon copier
You need to have the waste ink absorbers replaced, the cost of the absorbers should be around $20.00 and service is usually around 50.00. That is a very messy job, you must disassemble printer removed used/ waste ink pads in the bottom of machine reset ink counters and the reassemble printer.
Oct 24, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
426 people viewed this question
jasbo
jasbo
