Question about IBM ThinkPad X24 2662 Notebook
Help please my daughter has this computer and when we turn it on the lights will light up and sounds like the motor kicks on and can hear it booting up but the screen is black and none of the buttons work when pushing them
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Offhand, a couple of ideas, queries and suggestions:
  • remove the battery and try booting the laptop on AC adapter power only;
  • remove bottom panel cover for memory. remove memory, using a pencil eraser, clean the little gold pins. using a dry clean toothbrush, clean the slots where the memory sits in. re-install memory, try again;
  • use a can of compress air, blow on the air vents to clean out dust and debris;
  • try booting again. after sufficient time, pls check if pressing on the NumLock and.or Caps Lock would make the LEDs light ON/OFF even if there is no display.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
2002 dodge intrepid 3.7 liter. Check engine light came on, RPM's went up and down, car made a weird noise. I pulled over to the side of the road and shut the car off. It wouldn't restart. It w
Whatever happened, the engine computer sensed it and turned on the light. You will have to have the computer scanned for the trouble codes- a tech or mechanic could then follow the codes to find the problem.
Jun 08, 2013 | Cars & Trucks
Sony vaio VGN-A17GP not booting- 1 green light 2 amber are shown
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 16, 2012 | Computers & Internet
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 28, 2012 | Computers & Internet
My charger broke like six months ago and I never bought a new one. When I charged it my computer didnt want to turn on. all it does when I push the power button it turns green along with the power symbol...
  • Turn on laptop.
  • Laptop will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
May 16, 2011 | Dell Inspiron 6000 Notebook
Cap lock and num lock lights flash twice and will not boot up
Hi!
Do you hear beeping sounds along with the 2 flashes of capslock and numlock lights? For the meantime, I suggest we reseat all RAMs(Memory) in that computer/laptop. If you have multiple RAMs installed, please remove all of them then put one back first and turn the computer/laptop ON. If it boots up, put the rest of the RAMs. Please keep me posted. Thanks for reading my suggestion.
Apr 22, 2011 | Computers & Internet
MY daughters PHILIPS X57 WILL NOT BOOT UP. IT SWITCHES ON, THE FAN WORKS FOR ABOUT 2 SECONDS, THE HARD DISK LIGHT AND WIFI LIGHT LIGHT-UP FOR A SPLIT SECOND THEN NOTHING. NO DISPLAY, AND DOESN'T BOOT UP. ...
Its sounds like you have a faulty battery, take the battery out and take it to your local pc store and ask them if they will test it for you, if they find it is faulty you will have to buy a new one. Check that the power cable is working as well it might be that its not charging the battery so it might be worth taking that to the shop too for them to test. hope this helps and post back to let me how it goes.cheers.
Jan 30, 2010 | Philips (142440) Computer Speakers
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
450 power supply
The cd may be bad, or if the power supply is just marginal, it may be failing when the cd motor spins up.
Jun 04, 2008 | Compaq (176763001) 120-Watt Power Supply
IBM ThinkPad X24 2662 Notebook Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
